Question about Janome Memory Craft 9000 Computerized Sewing Machine
Need to know how to thread the bobbin - Janome Memory Craft 9000 Computerized Sewing Machine
  • 161 Answers
There is a guide on the plastic cover which is a good guide as to the direction, but before you put the cover back use the top thread to pull it through by putting the needle up and down and replace cover
Posted on Sep 11, 2010
How do I thread the bobbin of a brother xr-35
fit the bobbin into the bobbin case and feed the thread to the outside through the opening. it does not matter which way round the bobbin is in the case, then insert the case into the machine make one turn with the macine so that the threaded needle drops through the plate. when it comes back up it should pull up the bobbin thread with it. then take the two threads and pull them back and insert your material to be sewn.
I hope this was useful.
Feb 12, 2015 | Brother Sewing Machines
Using metallic thread, metallic needle. Bobbin case will not engage bobbin to bring up thread to needle. Bobbin is in correctly.
When using this slippery thread it is possible you need to change things a little. To change I mean you will have to stay with a straight stitch and place your needle at the left side of the plate. It may need to be placed on the right if the hook is rotating the opposite direction. Give it a try both ways to see which way works better. Anyway, you will need to stay with a straight stitch. When you first attempt to bring your bobbin thread up you need to hold on to the upper thread.
Dec 01, 2014 | Janome Janoe Deco Coputer 2011 DC2011
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Need to know how to properly thread , the problem is once we start to sew it moves a little then stops thread tangles on bobbin and breaks from top. we try different ways of threading
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
Mar 08, 2011 | Euro-Pro 473
Bobbin thread is comming all the to the top
I know this sounds like an insult, but check FIRST to be sure you have the bobbin inserted in the bobbin case correectly. If it IS in the case right, then check your upper tension. It generally needs to be at 3. Check also to be sure the top thread is between the tension disks. If it isn't, you won't have the right tension to connect the threads. You bobbin also needs to be wound tightly. A loose wind will cause problems with the bobbin thread. If none of these work, the bobbin tension might need to be adjusted by a professional. I hope one of my suggestions helps. If so, please let Fixya know by rating my solution.
Nov 23, 2010 | Singer Featherweight 132Q Mechanical...
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
How do i thread the bobbin
I have a new sewwing machine Eurp-pro Shark automatic but I don't know to thread the bobbin
Oct 07, 2008 | Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
