Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
Manual for Shop Vac 16 gallon, 5.75 hp wet/dry vac - to hook up wet pickup accessories
Pyrhyc
  • 2028 Answers
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Posted on Jul 16, 2008
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
kitt98
  • 26 Answers
SOURCE: How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Posted on Nov 05, 2009
  • 11 Answers
SOURCE: jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
Posted on Mar 08, 2010
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
I need a manual for a Sop-vac 1.5 gallon.
Have a look at this page and if it matches your product, you can click "user manual" on the right hand side to download a PDF version of the manual.
Shop Vac 1 5 Gallon 2 0 Peak HP All Around EZ Wet Dry Vac
Sep 19, 2017 | Vacuums
I need a manual for ridgid wet/dry vacs model #wd16500
I was unable to find the model WD16500 instruction manual anywhere online. In fact I did even find a link to that products owners manual, but when I clicked through the page no longer exists on Ridgid's site. I was able to find the parts diagram for the WD16500, and the instruction manual for the WD16600 which is also a 16 Gallon Detach Wet/Dry Vac, also with a detachable blower, and the model that even replaced the WD16500.
I also left you the number to Ridgid if you'd like to contact them, they may be able to mail you a paper copy of the instruction booklet.
I hope this helps you:
Instruction Manual:
http://www.ridgidparts.com/pdf/WD16600.pdf
Parts Diagram:
http://www.ridgidparts.com/cgi-bin/etcTable?showTable=1&table=WD16500-Figure1&image=Vac
Phone Number for the Ridgid Company:
1-800-4-RIDGID
If this was helpful, please be so kind to rate my answer as helpful, this is what keeps me coming back to Fixya to help people with their vacuum related questions. Thanks alot, I really do appreciate it.
Chris J.
GoVacuum
Apr 07, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
How do i turn the pump on to pump out the water this is a 16 gallon 5.75 peak horsepower wet dry vacuum.
If you want to get water that's in your vacuum, OUT of your vacuum, you simply need to remove the top and dump the water out. As far as I know, the Shop-Vac 962-16-00 won't "pump out" any water that's in it.
If you want to pump water from one place to another (for example, your basement to your backyard), this vacuum doesn't pump water "through" itself (like a sump pump) - it will, however, **** water up. You just need to dump it out once the vacuum is full.
Jul 08, 2009 | Shop Vac 962-16-00 Ultra Pro Canister...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
648 people viewed this question
Top Shop Vac Vacuums Experts
Jim Parker
Jim Parker
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
