Question about GPX KCL8807DT TV/DVD Combo
Volumn is too loud
When I turn on either the tv or radio they come on 17-18, which is too loud for me! I can mute it or vol down with remote. Is this ok or did I miss something in my instruction, I have KCL8806DT?
Thanks for your help
m.handley@att.net
  • Boise Mike 3 May 13, 2008
    I was looking for a fix so I could use the remote proporaly. This might help the factory to make the level a lot lower/or adjustable
    or a mute button on tv/radio as well the remote.
    Thanks Boise Mike 3.
    Novelist:
    Scholar:
  • 100 Answers
Hey Bosie Mike 3,
If you missed something in the manual so did I.
I was just pouring over the instructions and I don't see anything for a vol lock or anything of that nature. I can only assume 17-18 is the "standard" vol for the unit, and defaults to it when you turn it on.
Wish I could help more.
Jon
Go Ahead. Use Us.
Posted on May 07, 2008
How does one change the radio volumn for the alarm on a Onn model ONB14AV201? When the alarm comes on it's very loud. When i play the radio i can change the volumn but i can't find a sequence that sets the...
ONB14AV201 alarm clock with gradual wake alarm function. Radio alarm sound level will start from 0-15 within 12 to 15 second when alarm on. You can adjust the radio alarm volume by press the "ALM2/VOL-" or "ALM2/VOL+" buttons. The manual not mention the radio alarm sound level can be preset.
Feb 26, 2015 | Audio Players & Recorders
Phillips Magnavox 9P5034 C101 can't adjust volumn up or down on tv or with remote controller
Reset the code for r. control download from www. remotecodelist.com
2) clean the contacts battery
3) retight the spring contacts battery with pliers for better contacts.
4) otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
Hello, We have a Techcessories remote control for our tv. It dates back a few years and we cannot remember how to program same. It's a very simple, slim model. Purchased at Radio Shack and has a serial...
I have the 15-8911 remote; hopefully this helps you for yours.
To scan through all codes to find the correct one, the manual recommends to:
1) Turn on the TV
2) Press m (mute), then Power and hold both until the red light blinks twice
3) Press VOL- (volume down) three times
4) Alternate between Power and CH+ until your TV turns off (you may have to press these keys 50-60 times)
5) When the TV turns off, press m (mute). The red light will blink twice.
The remote is now ready to use.
Cheers.
Jan 15, 2011 | Audio Players & Recorders
Looking for remote codes for vizio sound bar and comcast remote
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Aug 28, 2010 | Vizio High Definition Sound Bar
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
Volumn inop,remote inop
sounds like the vol down button has stuck try agitating it ..good luck farr64
Apr 29, 2009 | Symphonic ST420FF 20" TV
Insignia remote will not turn on or off the TV
Setting the Remote to control power on your TV is really easy. You just hold down the TV power button and you start pushing UP on the channel button.
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
Iriver e 10
how to use the remote control.
1. go down to settings
2. remote control
3. find your tv brand (mines in ect(more brands))
4. point at tv (when on)
5. Scroll down list of numbers (#00; #01; ect)
6.go down to the bottom and if your tv dosn't turn off your tv isnt supported.
7. If it is supported click on the number your tv was
8. go back to the main menu
9. put it on hold (switch on side)
10. your done!
controls are:
up - channel up
down - channel down
left - volume down
right - volume up
power - off/on
smart key - mute
vol up - volume up
vol dwn - volume down
Jan 19, 2008 | iRiver E10 Digital Media Player
GPX KCL8807DT TV/DVD Combo Logo
79 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
