Question about Braun AB314SL quartz travel alarm clock.
My alarm clock seems to be keeping time for awhile, but then gradually loses time. I replace the battery and again, the same thing happens.
  • Anonymous Mar 14, 2014
    Unit is brand new. Accepts time and alarm settings but loses both when alarm activates.
  • 11,800 Answers
The quartz from the clock is very sensitive to the voltage of the source - even a minute difference can cause a frequency shift = time is no longer kept correctly. There's nothing you can do (the quartz can't be adjusted to compensate for the frequency drift) apart making sure you always have brand new batteries.
Posted on Aug 29, 2010
Please wait keeps flashing on the screen and the clock loses time
OEM radio issues. Flashing Time. Radio Not Working... - Drive ...
www.driveaccord.net/.../51717-oem-radio-issues-flashing-time-radio-not...
Sep 20, 2010 - When I reconnected the battery, the radio does not work anymore. ... I reconnected it, turned the key and the clock is still flashing. ... Wait about three minutes or so, and reinstall the fuse. .... Please let us know what it was. .... Naviscreen comes up but I can't do anything with it because the buttons are dead.
Novelty Simpson Jukebox Alarm Clock Radio Homer ... - Fixya
www.fixya.com/search/p94498-novelty...clock/welcome_please_wait
Novelty Simpson Jukebox Alarm Clock Radio Homer Simpson Animated Jukebox Alarm ... ...welcome Please Wait" Every time I try to use any handset the screendisplays ... This keeps flashing for several minutes, and never seems to resolve.
Troubleshooting - Shop - SiriusXM Radio
Jan 16, 2016 | Audio Players & Recorders
My GE Clock radio doesn't keep time. Radio is working. Have I pressed a wrong button ??
There are basically three types of electronic clock.
Quite old-fashioned are those that use the frequency of the mains electricity it is plugged into as a means of approximately keeping time. For practical purposes this type is more accurate than most mechanical types but may lose or gain a little and need adjusting from time-to-time.
If this type becomes unreliable there is nothing the user can do about it and an engineer would be needed or perhaps the garbage or recycling would be a better place.
The second type is the now very common quartz type where the clock circuitry keeps time by being triggered by a very accurate quartz crystal oscillator.
These types are generally so accurate it is worth providing battery back-up in case of power failure as well as preserving alarm and reminder settings.
If this type becomes inaccurate it indicates a problem with the circuitry and again recycling is probably the most practical option, though accumulated damp and dust inside can affect the delicate circuitry which might be restored to accuracy after a thorough internal clean.
I once had similar trouble with my clock radio which was caused in this instance by me forgetting how to operate it correctly. Spending a half-hour playing around with it refreshed my memory so in future I will remember when I have set the alarm to return the display to the clock.
The third type of clock is the radio controlled type that is set and keeps time by receiving a radio signal from a national atomic clock. They can do strange or unusual things if the signal is not being received properly or the clock is faulty but there is usually a function for setting the time manually though in my limited experience these aren't clocks for everyone and they aren't suitable for every location.
Feb 08, 2015 | GE Audio Players & Recorders
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
Alarm time keeps flashing
Switch of at the mains and removed back up batteries, left for a while and then started all over again and for the time being at least it seems to have fixed the problem
Jan 26, 2009 | Audio Players & Recorders
1997 Civic elecrtical problem?
All alarm issues aside, the radio losing its settings would make me go and clean the battery cables.
Jul 15, 2008 | 1997 Honda Civic
Time or Clock changes
check with antivirus software. same problem came again battery only problem!
Jul 01, 2008 | IBM ThinkPad T43 Notebook
NAP
JUST HOLD THE NAP BUTTON UNTIL IT NO LONGER IS BLINKING NAP, dont return it, its very good at waking you up in the morning, and is basically a good alarm clock, it just has a different way of turning nap off.
Feb 25, 2008 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
Small black device within RCA RP5420
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
Robert
Oct 23, 2007 | RCA RP5420 Clock Radio
250 people viewed this question
Top Braun Audio Players & Recorders Experts
richie46
ray gallant
Are you a Braun Audio Player and Recorder Expert? Answer questions, earn points and help others
