Question about Samsung SGH-U600
U-600 My u600 touch screen does not work, when i slide the phone up.BUT when it is not slided it seems to work perfectly... thank you in advance.....
  • 122 Answers
Cracked flex cable change it with original and same rev.
Posted on Mar 09, 2010
Fiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiin
Posted on May 07, 2008
  • fox_2005123 May 07, 2008
    fiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiin
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
Screen problem
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jun 30, 2010 | Samsung SGH-U600 Cellular Phone
Instruction to replace u600 slide flex cable
download the service manual for the sgh-u600.you need experience and special tools.isnt so easy.be carefull with the parts screws etc and check the rev. before order the flex cable.USE ONLY ORIGINAL!
Jul 16, 2009 | Samsung SGH-U600
Locked in silent mode.
I had the same problem with my u600 until just recently. It's an easy fix:
Slide your phone open, then press and HOLD the "#" key until you see a message on the screen that says, "Exit Silent Mode". Voila! Your phone makes sound once again.
I hope this helped :)
Apr 15, 2009 | Samsung SGH-U600 Cellular Phone
Sgh-u600
u both need to takeur fones to were u got it froman explain the situation they shud do it for u both freely as u got ur fones from there shop
May 07, 2008 | Samsung SGH-U600
U600 touch screen
Here is a link to a forum that may help answer your questions.
http://www.howardforums.com/printthread.php?t=1230043&page=8&pp=15
May 07, 2008 | Lands Phones
Light sensitive buttons not working
I had simmilar problems, re-setting the phone was no help.
I had to replace the flex cable that connects the screen to the main board in the end and phone now works perfectly.
Nick
Jan 29, 2008 | Samsung SGH-U600
Samsung SGH-U600 Logo
105 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
