Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
I have a jabra BT 2035 bluetooth headset.I have lost the phone it was paired with.Please advise how I can pair it with another phone
Long press on the headset button for 15 sec long and you will be able to pair it again with any other device
Posted on Jan 18, 2011
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
Hi, i have just set my JABRA BT 2070 however i accidently clicked on LETS FORGET this and now my jabra bt2070 is not pairing ny longer, please help
1. Switch Bluetooth headset off. 2. Press and hold the answer/end button until a solid blue light comes on. Headset in pairing mode. 3. Go into phone's bluetooth options and "search/look" for devices. you should see the headset. 4.Pass code is "0000"
should connect and be good :)
hope this helps
Apr 17, 2011 | Jabra BT250 Consumer Headset
Cant connect my Jabra BCE OTE4 with my LG 8300 cell phone...help
default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
Aug 21, 2010 | Jabra Bluetooth Headset with Adjustable...
Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
May 16, 2010 | Jabra BT350 Bluetooth Headset Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
I lost the instructions. I want to pair my Jabra bt125 with my motorola razr
1. I have the Jabra 125. You can get the manual at www.jabra.com if you have a different one.
2. Turn off your phone. Power off. The order of powering on devices is the key.
3. Press and hold your Jabra power button until it's glowing blue (not flashing blue light--but constantly on)
4. Then turn on your phone...and look for wireless devices in your phone menu.
5. Make sure you have bluetooth turned on.
6. the phone will find the Jabra, and then will ask to pair with it. passcode is 0000.
7. That's it.
Again, the key is the order of turning on devices.
Thanks.
Jun 05, 2009 | Jabra BT125 Headset
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jun 03, 2008 | Radio Communications
Pairing
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Manual for Jabra BT 150
Go to page 4 Pair it with your phone
Did you know that if you have a bluetooth card in your computer you can also use this headset to listen to music. Do it everyday. It's great!
Mar 22, 2008 | Jabra BT150 Wireless Headset
Jabra BT 350
u gotta make ur jabra go to FIND ME Mode, u do this by turning it off, Turn it back on by pressing power for 6 to 8 seconds until the light is in flashing mode, and make Ur razor look for devices and pair it with the 0000 code. hope this works for you
Feb 11, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
439 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
