Question about Compaq Presario 5000 PC Desktop
Did you fix your Compaq 1220?
Hello, JustBrutal!
I'm really sorry, just find you on FixYa.com. Today my monitor P1220 lost a picture and have the same problem.. - orange LED blinks 7 time :] Did you fix it? If you did, can you suggest me a way to solve a trouble?
my e-mail: bk@mail.ru
Thank you very much!
And Good Luck!
Konstantin Bondar
    Problem Solver:
  • 9 Answers
Any time you have a orange light . The monitor or video card can be at fault. First check the monitor. Turn it on and see if it goes from green to amber. Check all monitor cable connections. to make sure the all 15 pins are there . If monitor displays a message that check video signal most likely video card is the problem. Make sure you have the cable connection plugged in the back of the computer into the video card. Usually a picture of a monitor. Then afterwards turn the monitor on first then the computer. If you do the other way around then the video card most likely will not engage.
Posted on May 13, 2008
Compaq p1220 crt monitor...no power dear, when the electric power generator is running and i turn on monitor it works....but on the station electricity its does'nt powers on....infact the both voltages...
Sounds like there is an issue with the power coming in or there is a problem with the internal power system have you tried any other montiors on the power generator?
Feb 28, 2011 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
The monitor light red light that comes on and off when you turn the tv on and off is flashing and the tv will not come on.
Just fix this 2 years old TV today due to bad cap in the 5v power supply, I would suggest you to take a look in the power supply module first.
See my pictures here: http://s807.photobucket.com/albums/yy352/budm/Samsung%20LN32A330/
This is really bad that expensive TV failed due to cheaply made caps. I would not recomend SAMSUNG any more to my firends after seeing this.
Please post back what you find, it can be problem some where else also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 30, 2011 | Samsung LN32A450 LCD Monitor
My P1220 has the problem that when it goes to powersave mode, it completely gets off. and it will not switched on for a while. if we kept the monitor fre for one or two days, it will work as usual(until it...
NO PC stated, NO OS STATED, must we guess it all?
the last running CRT monitor on earth fail 17 years old.
how amazing, no:?
lost the manual you did, google finds is if you had tried.
the OSD menu, works. push mon. menu button
turn off the sleep timer
RTM always works why not do that.
read the manual
your MON is so old its before modern VESA spec sleep modes were invented,
so it had this silly feature called the sleep timer, with clock
yes has a clock too, crazy no?
https://www.manualslib.com/products/Compaq-P1220-187767.html
page 6pdf.
tells me it does have vesa mode, sleep off the sync pins
on the same page this old relic,has DDC modes
but only work on moden PC< DDC uses a pin that was never used before on the VGA jack.
that same page also states, DDC2Bi (plug and play) only works on MONItgor jack B..
so note tell me your PC or its video card model if used.
or whaT this is (windows95.)>?'
we cant help much can we.
but you can test your monitor on another PC.
if that fails, the monitor is bad
but you must try both MON, rear VGA ports.
if the PC was dead, i sure can be.
youd have tried another barrowed monitor to prove that.
easy.
Oct 16, 2017 | Compaq P 1220 22" CRT Monitor
When i turn my monitor on it shows no picture and it makes a sound like it is running the electricty went out and when it came back on thats when the trouble started thank you
It's time to spend $100 to buy a brand-new 19-inch LCD monitor,
or $200 to buy a brand-new 22-inch LCD monitor,
rather than paying a TV/CRT technician $50 to $75 per hour to try to fix the "antique" monitor.
Aug 05, 2010 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
Monitor moving on its own
On your physical monitor adjust the verticle and horizontal lengths to take up the full length of the screen. The CRT guns have to draw the exact location of your screen, so extending them to the edges will be easier on the guns. You can also try raising the refresh rate, although that probably wont fix it but it will help on your eyes. and if You have other options like convergence, focus, etc. Try messing with those.
Nov 22, 2009 | Compaq P 1220 22" CRT Monitor
To use as monitor, what cable do I use?
Male VGA to Male VGA (15 Pin D-Sub Male -> 15 Pin D-Sub Male)
Sep 07, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Compaq P 1220. how to enter service mode (menu)
You don't need to enter the service mode, simply turn off sRGB (from one of the other menus) and you'll be able to change the color temperature.
Feb 04, 2009 | Compaq P 1220 22" CRT Monitor
Compaq P1220
If that monitor is out of warranty, it's pretty much a throw away item. If you can find a "donor" monitor with a cracked CRT or case, you could probably swap the high voltage units and get it going again.
Oct 04, 2007 | Compaq P 1220 22" CRT Monitor
Compaq Presario 5000 PC Desktop Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
