Question about D-Link Computers & Internet
Windows was unable to find a certificate - D-Link Computers & Internet
    Sergeant:
  • 223 Answers
This is a security setting in your browser, look in your browsers menu for Tools >> Options >> security tab. its set in there to "always check for certificate", try to set it back to defaults using the "default level" button. Its really not much of a security issue, but definitely can be annoying. Hope that helps you
Posted on Aug 29, 2010
  • Trevor Groves
    Trevor Groves Aug 29, 2010
    Did this work?Please use the solution rating "thumbs" if your problem has been solved, or make another comment if your still having trouble. Thanks! Gurvy
Coby model 620 mp player i need the drivers it will turn on and the computer was unable too find them
The drivers, made for older windows versions, won't work on a Windows 7 or up machine. Not even in compatibility mode. Microsoft needed to make Windows more secure, so only allows drivers in there modern operating systems when they have a Microsoft certificate. For a certificate the manufactures must use Microsoft protocols, ask Microsoft for certification, and pay for the tests Microsoft does, to check the software is working correct. So no manufacturer will ask for certification of drivers for hardware they no longer sell.
Long story, but unless you can write your driver yourself, or you can find an universal camera driver (not sure something like that exists) you won't be able to use the camera. Nobody does tell you, after you update your OS you also have to buy new hardware to.
Feb 10, 2015 | Coby MP620 MP3 Player
Windows unable to find certificate to log on using netgear wna1100
Windows doesn't need a certificate to logon to the router.
It may need one to logon to a web page.
Check by accessing another web page.
Dec 02, 2013 | NetGear WNA1100 WirelessN 150 USB Adapter...
Windows was unable to find a certificate to log you on to the network OS is XP SP2 N614
Here's how to connect to your wireless router if you are getting this message:
First, click on the wireless icon in your taskbar and under Related Tasks, choose Change advanced settings.
Now click on the Wireless Networks tab and select the network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box. If the box is checked, then that is why you were getting the "unable to find a certificate to log you on to the network" message because Windows is looking for one, but your wireless router is not setup for certificate security.
And that's it! Once unchecking the box and try to reconnect to the wireless network, everything should work fine.
Hope this helps!
Apr 06, 2011 | NetGear WGR614 Wireless Router
"windows was unable to find a certificate"
you will need to check the certificate of the site that you are going to.
they may not have a current certificate and this is why you will get this message.
May 20, 2010 | Linksys WRT160N Wireless Router
Certificate error in yahoo mail
basicly this meens you have not been doiny your windows updates this can occur for many reasons such as you may have a pirate copt of windows and dont want micro scam to turn off your version of windows. If you are unable to do an update for this or other reasons then try using a third party internet program such as firefox
Apr 25, 2010 | Microsoft Windows XP Media Center Edition...
Error code:12045 in windows vista
is this he first time that you received that problem/error?
some sites have security/authorization/ certification before you can sign in..
***This error occurs when the client does not know about the certificate authority that issued the server certificate. The problem may be corrected by installing the certificate authority's root certificate. A list of all installed certificates can be viewed from Internet Explorer. From the View menu, click Internet Options, click the Content tab, and click Authorities.
>> for more info go to support.microsoft.com
Jul 17, 2008 | Microsoft Windows Vista Ultimate Edition
Connecting to network
[QUOTE]The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
Google shows 37 hits with this exact phrase.
This is caused by setting the encryption to WPA-RADIUS instead of
WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it
will work.[/quote]
Jan 16, 2008 | Linksys Wireless-G WRT54G Router
Error message: "Unable to establish a secure connection"
This error can occurs because the VeriSign Certificate Authority (CA) has changed the hashing algorithm that is used for new Secure Sockets Layer (SSL) server certificates from Message Digest 5 (MD-5) to Secure Hash Algorithm 1 (SHA1). A supported fix is now available from Microsoft for Windows CE 2.11 and Pocket Explorer 3.0 this fix can be found at: http://www.microsoft.com/mobile/handheldpc/downloads/128bit.asp Note: After you have downloaded and installed the fix, be sure to soft reset the device.
Sep 15, 2005 | NEC MobilePro 770
Error message:"Unable to establish a secure connection"
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Computers & Internet Logo
115 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
