In advanced bios features CD rom boot priority is missing, how do i get it back
  • 11,800 Answers
Select the first boot device - a secondary menu will open . In there you will find the cd option - select it and put it first ion that submenu; when you will exit from it the first boot option will change to cd.
If it's not in there that means that the cd isn't recognized by the BIOS - put it as master on its own cable and leave the hard disk as master on the other cable.
Posted on Aug 29, 2010
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Tip
NTLDR is missing?
A missing NTLDR is a common start up error that can appear on the screen while booting a computer running a Windows operating system. This error may occur due to number of reasons.
NTLDR is short for Windows 'NT LoaDeR'. It's entirely involved in the loading of the operating system.
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk/hard drive that contains no operating system or CD-ROM drive. Firstly what you've got to to is press the Delete key multiple times as your computer boots up until it displays the BIOS screen. Then you will need to find the boot disk priority setting. Make sure this is set to your drive that has Windows on it (as priority 1) and not the CD-ROM drive/stiffy drive or empty hard drive. You can set the CD-ROM/DVD-Rom drive to priority 2 if you like.
Once you have checked that and have set it to your master/primary hard drive (the one that you've installed Windows onto), save and exit the BIOS and on reboot your system should boot into Windows normally.
If you only have one hard drive and the boot disk priority 1 is set to it and you still get this message, then it means that your NTLDR is either corrupted or missing. In the BIOS you will need to change boot disk priority 1 to your CD/DVD drive. Once this is done save and exit the BIOS.
As the PC reboots insert your Windows install disk and let it load.
Hit [R] when prompted if you need to repair system files and then [C] at the 'Welcome to Setup' screen to start the Recovery Console. This will let you copy NTLDR from the CD to C:\
If this fails then you will need to install a fresh copy of Windows on your system. All is not lost though as you can still save your data that is trapped on the NTLDR missing hard drive. If you are not quite seasoned with computers and electronics then this is the job for a PC technition. Simply take your PC down to your local Computer store and explain your situation (Don't forget to take your original Microsoft Windows with you). They will back up your data, re-install Windows and the put all your data back on for you.
on Nov 15, 2010 | Computers & Internet
Tip
How to Fix NTLDR is MISSING
1. Locate you Windows XP CD and place it in your CD-ROM drive.
2. Restart your computer, or turn it off and then back on.
How to fix NTDLR MISSING error.
3. When you computer restarts you should eventually see the words "Press Any Key to enter Setup". If you do not see these words and it goes to the screen that gives you the error message, you will have to change your boot priority in your bios settings.
Changing boot device priority:
A. When you see you’re the first screen, the boot screen, press delete a few times until your computer beeps. Pressing the delete key will bring your computer up into the bios settings. The key you need to press may differ from computer to computer. If the delete key doesn't work for you, contact your computer manufacturer and ask them what key you need to press to get into bios.
B. After you are in your bios settings you will need to navigate to your boot settings. Depending on which type and version of BIOS you have, this process may be different. Either way, there should be a section called Boot or Boot Priority. Navigate to that and make sure that your CD-ROM has top or first priority. After you have don't that, save and exit (press F10).
4. Once you see the "Press Any Key to Enter Setup" message, go ahead and press any key.
5. This will start the Windows Setup Process; it will take it several minutes to load.
on Feb 04, 2009 | Microsoft Windows Vista Ultimate Edition
Wont boot ms 6567 from cd/dvd
1. Try to go to the BIOS 2. under the Advance BIOS Features---> go to Boot Device Priority 3. under Boot Device Priority -----> make CDROM as the first boot device 4. let the 2nd and 3rd boot devices as Disabled 5. Press the Esc key 6. Choose the save and Exit option 7. Make sure the cd is in and restart the computer
Thanks for choosing Fixya
Jul 18, 2011 | MSI 645E Max2 (MS-6567) Motherboard
Cd Group Boot Priority not installed
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Mar 27, 2011 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
PXE-E61: media test failure/PXE-M0F: Exiting PXE ROM/Operating system not found. This message is coming up on my screen. The only thing I can access is F2
Hi, welcome to FixYa.
Apparently, the error of your system is missing operating system, this could caused by many things, from broken hard disk to missing boot record such as MBR.
First, try to fix your BIOS start up setting. Depend on your BIOS setting, go to your BIOS by pressing F1 or F2 (apparently this is your key) or END during boot time. Then go to Boot Setting (this name is vary in any BIOS manufacture, so try to locate the similar name). Change the boot priority with first priority is your hard drive,
If you still don't able to boot, this can be caused by missing boot record such as MBR. This is little bit trickier. The fastest way (I assume you use Windows), is to insert your Windows installation CD/DVD then boot from there (by changing boot priority again from BIOS, or some new BIOS support pressing F12 to choose boot device). After you boot from there, repair your Windows.
I hope this information will be helpful. Thank you for using FixYa!
Mar 07, 2011 | Acer Aspire 3680 Laptop
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
My dell desktop doesn't start or boot from cd rom
Basically you need to go to Bios to change your "Boot device pripority". Please follow these steps to do this.
Please follow these steps to install XP on your PC.
1. Please start your PC with power button. At the very first screen, at the left down corner, you will see the button to be pressed to go to Setup i.e. Bios of the PC. For most of the PCs , it is delete button. For some of them, it is F2 also. So, after starting the PC press Del to go into setup.
2. After you enter setup of the PC, please go to Advance bios setup.
3. There you select Boot device priority.
4. here the first boot device priority should be CD ROM, then the HDD. Please see the instructions given at right down corner and select this priority.
5. After you rightly selected boot device priority as given above, Press F10 to save the changes and then press F12 to exit.
6. Now the PC will restart again, but be sure that you put win XP cd in the drive before it restarts.
7. Now you will see a note that : press any key to boot from CD ROM, so please press any key.
8. The PC will boot from the CD ROM now , now you can follow the instructions given on the screen.
May 07, 2009 | Dell Dimension 4600 PC Desktop
NTLDR file is missing please reboot u r system
hmm seems like your computers got a virus away this is how to solve it:
Feb 04, 2009 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
