Question about Dryers
Turned on my dryer and it makes a grinding sound.
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed.
Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
This should solve your noise problem.
Please rate me
Posted on Aug 29, 2010
My dryer makes a loud grinding sound and won't turn?
The grinding Sound is the motor attempting to start and not being able. If you find nothing binding the drum and you can turn it by hand fairly easily you will likely need a new motor. Otherwise, find and remove what is causing the drum from not turning
Nov 14, 2015 | Dryers
Drum will not turn
there is a belt that drives the drum in your dryer it is broken
the grinding sound is caused by the the wheels that the drum rides on broke or the bearing went out
Apr 14, 2014 | GE Dryers
Dryer starts to make a grinding sound and then stops. Starts again, but only runs for about a minute and starts grinding and stops.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Amana NDE2335AY Electric Dryer
My Gallery Series dryer makes an intermittent noise when i turn on the dryer. It sounds like the drum is getting caught up on something. It sounds like grinding gears. The noise comes and goes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Dryers
And Admiral ser# 3281223 When dryer is turned on, it makes a loud grinding sound when it tumbles
heatman101
Aug 29, 2011 | Dryers
When you start the dry it makes a loud grinding sound. The drum still turns but seems to turn harder.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 14, 2011 | LG DLE2512W Electric Dryer
Dryer is making a god awful squeaky/grinding sound when turned on. It will stop for a bit and then start up again every 4-5 minutes.
heatman101
Asker
Dec 29, 2010 | Amana NDE5805AY Electric Dryer
Dryer doesn't want to run- makes grinding noise
its sounds like a worn bearing problem.with the m/c switch off ,turn drum by hand and see if it is hard to do so.if you get a gritty feeling in your hands or hear a grinding noise,then that is probably the bearing.
Jul 23, 2009 | Dryers
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
Grinding noise
In my humble opinion, a dryer making a grinding noise is worth repairing. Possible Problems:
Worn Drum Rollers (Very Likely): More of a thumping / grinding sound. Replacing drum roller supports is considered to be a routine "normal ware & tear" repair with parts costing about $15 - $20 or so. Its' kinda like a tune-up for a vehicle. The rollers can be located in a couple places, but are typically located on the inside rear of the drum; upon dis-assembling the dryer.
Broken/Loose Blower Fan Wheel (Likely): The blower wheel can become loose or brake off the motor shaft and can make a "rumbling / grinding sound and can run about $15 - $25 for the part. The degree is difficulty when repairing a little high, but is commonly performed.
* Note: Removing and threading the blower wheel is reverse to prevent the fan blower from natually spinning/coming-off "Righty loosey, lefty tighty"
- C
Jan 27, 2009 | Maytag Dryers
Dryers Logo
Top Dryers Experts
