Question about Garden
My powermatic wood lathe has developed a problem noise (click, click) that occurs only when the lathe is running forward. The noise is not there when the lathe is in reverse. Is this a bearing problem, and if so, what must I do to correct the situation? Edmund B. Campbell, Jr. 941 485 6484
  • ebcjr522 Aug 29, 2010
    MY problem is with a Powermatic Lathe (Model 3520B), NOT with a chain saw.
  • ebcjr522 Aug 30, 2010
    I discovered two loose set screws on the upper pully wheel. After tightening them, the moise stopped.
  • 905 Answers
Hello Edmund,
Normally bearing noise will happen in both directions, forward and reverse.
You didn't mention the model # of the lathe itself, but here are few things that you can do to narrow the scope of the problem.
1) Your motor probably turns at the same RPM regardless of spindle speed. So, if your spindle is turning at say 150rpm, and you hear the click at the same speed as 500rpm, then the noise is likely coming from the motor, or the transmission.
2) Most motors also turn in 1 direction. Verify that yours follows this or not. If the motor doesn't reverse, then again, you are likely looking at the problem being in the transmission.
3) If the clicking noise is present all the time, then you can eliminate the tail piece if you don't have work in the spindle.
4) Try disconnecting the motor from the transmission, and see if noise goes away. If it does, then you should be able to rotate the transmission by hand, and possibly feel the noise as it occurs.
5) Otherwise, with the motor disconnected, rotate the spindle to see if you can feel the clicking noise.
6) A definite sign of bearing failure will be play on the input shaft, spindle, or an intermediate shaft. Check these and make sure that there is no lateral movement.
It would be best for you to contact the manufacturer and obtain a parts manual for your lathe. Then you are able to see how the lathe is assembled, as well as likely sources or areas that can be the source of your clicking noise.
Good Luck!
Posted on Aug 30, 2010
  • 10,319 Answers
Bearings will make a noise if one or more bearings get a flat spot on the round bearing. the noise will be heard in either direction as well. More than likely the noise you hear is from the motor for they do have a clutch in them for forward drive modes and not for reverse modes
Posted on Aug 29, 2010
I hav a Powermatic model E16 planer, the motor has been changed to 1 phase 220 amp , the speed sees too slow, what speed should the cutters turn
If it's got the 3-3/4" three-knife cutterhead, it should run pretty near to 5000 RPM. If it's got the 1-7/8" two-knife cutterhead, it should run at nearly 10,000 RPM.
That planer should take a 3600 (3450) RPM motor.
Dec 29, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Where are the gears ?
I see no gears in the manual You can move the belt over to get a different speed if that is what you are asking.
http://content.wmhtoolgroup.com/assets/manuals/1352001_man_EN.pdf
Nov 28, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Motor stopped while turning. It does have power but will not run.
Motor should have red push botton on back or bottom of motor. This is reset over load breaker . Should be out, just push in until it clicks.
Feb 15, 2013 | Powermatic 1352001 3520B 20x35" Wood...
How do i go through a used electric lathe motor make sure its good
If it hums when its turned on look at the capacitors. Visually inspect the cooper winderings, if there is any discolored portions, ones that are blackened. It might have burned up a coil.
Oct 09, 2012 | Powermatic 1352001 3520B 20x35" Wood...
My wood lathe is making noise
Thats a good thing, means you making chips. lol. What kind of noise exactly?
Lathe motor making noise
use a wooden stick and place it to the motors housing and put your ear to the other end of the stick while running. If a grinding noise is heard to your ear the bearings are bad. If a screeching noiose is heard the armature is swelled causing the fields to scrape the armature while turning
Oct 09, 2012 | Jet JWL-1236, 12" x 34-1/2" Wood Lathe...
The hand wheel on the tailstock is getting harder to turn avery day. I've lubricated it any nothing helps. What's the next option? And no, the lock isn't closed or anything simple like that.
Take the entire screw out of the tailstock and examine the internal and screw threads carefully. Suspect something is 'galling' the threads causing the bind or possibly, the screw has been bent. You may have to chase the threads with a suitable tap and die to get things working again. It may also be that the lubrication did not reach the entire thread. Hope this helps!
Jan 16, 2011 | Powermatic 1352001 3520B 20x35" Wood...
Looking for info/ manual for a wool lathe
look under cwl12d clarke wood lathe manual. this has all the instructions that are almost the same as the nwl37-2 i have a nwl37-2 and this manual shows what should be there.
Jan 22, 2009 | Powermatic 1352001 3520B 20x35" Wood...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
