The DVD (JVC NV-410) is stuck on pause with a DVD inside of it. It won't open, the power can't be turned off, and the play, menu, rewind, fast forward, etc... functions are triggering anything. Please help.
    Novelist:
    Scholar:
  • 100 Answers
Greetings lwilly,
I would suggest fully unplugging the unit for roughly an hour. This should reset the unit.
Once you plug it back in, I would first try and eject the disc before attempting anything else.
Hope this helps
Jon
Go Ahead. Use Us.
Posted on May 07, 2008
Why does my Panasonic NV-SD200A play for 4 seconds then stops and has no kind of output?
General when the electronics detect a fault all functions will stop to prevent damage. Check inside look for broken plastic parts in the mechanism.
Aug 10, 2014 | Panasonic Televison & Video
Why does my vcr play, fastforward and rewind for 4 seconds then stops for no reason?
When the mechanism is damaged the VCR will attempt to play and then shut itself down to prevent any further damage. If you remove the top cover and look around inside you will probably find the cause of the failure.
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
I have a phillips universal remote and I need the code that matches to a Liteon dvd player and recorder. Model LVW-1101HC1
The codes that I have are for the LVW-1101 ( and possibly 1105). The remote responds to the JVC remote code [0623] but the individual command buttons are scrambled and need to be programmed in-unless you have the remote w/ learning):
266-play 286-TV (as source)
292-Fast Rewind 296-Cursor Rt.
301-Fast Forward 304-Record
316-1 325-7
326-Cursor/Channel Up 328-Timer
329-0 330-Menu
364-Setup 365-Select
367-Stop 368-Previous Track
369-Cursor/Channel Down 385 Commercial Skip
389-Source 390-Next Track
413-Cursor Left 416-Display
417-2 420-Open/Close
421-3 427-4
431-Top Menu 433-Navigate Menu
452-5 453-Easy Guider
454-9 455-Power
459-6 462-Tools
474-8 479-Pause/Step
500-Channel Editor
Finding the codes is not hard-just tedious.
Aug 18, 2009 | Televison & Video
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Apr 18, 2009 | Televison & Video
Rcr4358 and rcr312w remote troubles
lost the codes for the remote and need a list of codes rca remote rcr4125 and also have a rca tv
Aug 25, 2008 | RCA 3-Device Universal Remote with...
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
