A magnet fell in the space between the inside of the front panel and the tumbler. I need to take the front panel of the washer off to retrieve it. Can you tell me how to get the front panel off?
  • 150 Answers
Make and model?
Posted on May 07, 2008
Dishwasher, a bolt and washer fell into the drain in the bottom. Is it safe to use? What could be the complications. Kenmore ultra wash 2
Complications will be it gets sucked into the motor drive of the washer. At that point you are buying a new washer. If the washer /drain pipe has plastic insides you can use a mechanics magnetic tool (cheap $5) to retrieve it. Otherwise, pull the washer and tip it upside down and hope they fall out.
Nov 17, 2017 | Kenmore Dishwashers
Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Mar 20, 2009 | Frigidaire Washing Machines
Frigidire front loader washer
The magnet goes on the front piece of the detergent tray. You must be getting a "DDO" (Detergent Drawer Open) error message. When you removed the detergent tray for cleaning, you probably also removed the white plastic (front) portion of the drawer from the darker plastic reservoir portion. That's when the magnet fell out. That magnet has to be in place for the washer to function properly.
It goes into the white plastic portion of the detergent tray. It is placed in the vertical position just inside the vertical wall of the front portion of the drawer on the right side (of the detergent tray) as you are looking at the washing machine. You really have to look for its' location, but with some effort you will see a vertical slot with "plastic retaining clips" which hold the magnet in place.
Hope you are successful but if not, post another problem citing details about what you have tried. I tried to post this message to you twice already, but the web site will not accept it for some reason. Perhaps they want you to purchase their "professional" (spelled expensive) service to resolve problems. We'll see.
Feb 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gltf2940e front loading washer - dispenser drawer magnet replacement
When you are looking at the drawer, the magnet stands upright on the far right side just inside the outer front casing about halfway down. There is a small plastic clip that holds it in place. You don't need to take anything apart to reinsert the magnet, just open the drawer, but it may be easier to see the location if you pull the drawer all the way out of the hole.
Nov 02, 2008 | Frigidaire GLTF2940E Front Load Washer
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Changing door hinge position
you could try and pop off the door seal from the w/m front and reach down to see if retrieval is possible.
Jan 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
