Question about Honda 3000 Watt Portable Generator
I own a HondaEU3000I Handi generator and have the following problem It starts on choke and will only run if I leave the choke on. What would be the problem
  • 10,319 Answers
Chokes are used to draw gas through the center jet to run. If the choke is not working properly and it is not closing all the way the engine cannot draw gas through the center jet and will not crank.
Your problem is just the opposite of that
Yours is getting too much air so that is why it runs only with the choke closed
You will see two set screws with springs attached to them. one is for fuel adjustment and the other for air mixture. Try adjusting the two in all the way and back off 1/2 turn each then try and start it. If not firing look at this website below and click on the video to view how to clean out the jet
http://www.lawnmowerman.tv/Videos.asp
Posted on Aug 29, 2010
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Engine won't accelerate past low idle
It could be the low oil cutoff check the oil level and add oil if necessary. See if that solves the problem. Hope this helps
Jan 06, 2014 | Honda EU3000i Handi Super Quiet Generator
Honda generator
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
Oct 19, 2013 | Electrical Supplies
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
WHEN IT IS PUT UNDER A LOAD IT WILL NOT STAY RUNNING UNLESS YOU LEAVE THE CHOKE ON
Possible that the engine is not getting sufficient fuel for running and so the choke action is needed. You need to check if the oil switch is cutting off the power, - if so replace oil.
Secondly the fuel settings might need a check up. You might need to clean/reset the plugs/spark gaps and also overhaul the carburator to solve this issue.
Jul 08, 2011 | Honda Electrical Supplies
What's the best choke setting for starting a cold generator
Full choke to start, open choke partially immediately the engine starts to where the motor runs smoothly, continue opening as soon as you can while keeping the engine running smoothly. Be sure to open fully before leaving the unit, running it with the choke partially on can cause a rich fuel condition which tends to wash the oil off the cylinder walls and it also dilutes the oil with gasoline.
lp
Dec 26, 2010 | Coleman Powermate Portable Generator...
How to start a gas generator (should the choke be in or out, to the right or the left before starting
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Nov 04, 2010 | Generac Power Systems Generac 0057890 3250...
Homelite Lightnin Bug Generator not getting gas
try leaving your choke partially on it may not be getting all the gas it needs,see if it will run then, it wont run full throttle, but this will tell you its not getting enough gas
Oct 05, 2009 | Electrical Supplies
Hi my honda generator runs for a couple of min then turns off this seems to happen more when its cold but happens when warm just not as much anyone have a idea of what it is
First off, Jason, what is the model number of your generator? It helps to know what product you're having trouble with so the correct information can be provided to you to help you solve your problem.
It sounds like the choke is staying on after starting. If you have an automatic choke, check for free movement of the choke spring and lever assembly (behind the carb). If it's a manual choke, remember to push it in once the engine is running smoothly (after 20 seconds).
It could be a fouled sparkplug or clogged air filter element too, but, again, without the model number it is very difficult to solve your problem.
You need to go to the Honda website and download a copy of the owner's manual for your specific generator and follow the step-by-step instructions for operating and troubleshooting your generator.
Here's the link to get your free online owners manual:
http://www.hondapowerequipment.com/products/manuals/
Hope you find this info Very Helpful and best regards!
The following helpful basic steps are from Honda:
To start your generator:
  1. Review your owner's manual to ensure familiarity with your generator's controls and operation.
  2. Move the generator outside.
  3. Check the fuel level and add more fuel if necessary.
  4. Check the oil level and add oil if necessary.
  5. Check the air filter and clean if necessary.
  6. Turn the circuit breaker off.
  7. Turn the fuel valve on.
  8. Start the generator.
  9. Allow the generator the warm up for a few moments before turning the circuit breaker on.
  10. Connect the appliances or the transfer switch if applicable.
Aug 20, 2009 | Electrical Supplies
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Honda 3000 Watt  Portable Generator Logo
238 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
