Question about Zenith B25A76R 25" TV
Zenith TV modelB25A74R picture rolls
Picture rolls, then stops for a few seconds and the rolling begins again.
  • dwill918 May 10, 2008
    25" Direct View Traditional Console Television B25A74R
    Limited TV repairmen in area. Floor model and cost to pickup and diagnose is $100 plus parts. OR is it time to junk the set?
    Original manual misplaced long ago. But have downloaded service and paid for specs download. This is as useful as the information is going to get.
    Sergeant:
    Champion:
  • 304 Answers
Can you please tell us what model maker of your TV unit..
Posted on May 07, 2008
  • Elizabeth Krijt
    Elizabeth Krijt May 07, 2008
    Have you done any initial check or test on the unit.. & please kindly provide us some other useful info. regarding on the problem.
    anyway try to look for bad stk's on convergence
    module on the TV..
    Post back, if still need assistance.
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Tv picture rolling vertically
Vertical oscillator and output section should be trouble shooted. It is a skilled job.
Mar 09, 2012 | Zenith Televison & Video
Zenith C27A24T 27" TV -
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ( in your case )...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 21, 2011 | Zenith C27A24T 27" TV
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Rolling picture
Dear, this is problem in the circuit, you need to change the VHold you your tv, but it is not an easy job, if you don't have knowledge about fixing it, it would be better to visit the repair shop, otherwise it will affect the picture tube quality and cause further damages.
Best regards.
May 27, 2009 | Televison & Video
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Tv want stop rolling i can hear sound good but the picture i cant see for it rolling in red
I will need the model number to be able to even begin to help make a suggestion as to the cause of the vertical sync problem. can you explain what you mean by rolling in red?
Jun 08, 2008 | Televison & Video
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Zenith B25A76R 25" TV Logo
158 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
