Question about Dacor DCM24 Convection/Microwave Oven
No sound from unit when making pad selections
When a pad is pushed there is no sound, just shows on the window that you have entered something, before there would be a sound with each entry that one made,
  • Dacor Master
  • 9,047 Answers
From page 24 of the owner's manual:
Audible Signal Elimination
If you wish to have the oven operate with no audible
signals, touch HELP GUIDE, the number 2 and
STOP/CLEAR.
To cancel and restore the audible signal, touch HELP
GUIDE, the number 2 and START.
If you don't have your owner's manual, I've uploaded it to our site for your convenience:
http://www.microwavedisplay.com/dcm24_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
GE Spacemaker JVM1450AA001 started beeping then said to enter the time, which I couldn't enter because none of the panel buttons work, and is now showing F3 code? Sounds like the touch pad pa
Yeah, I think you're right, sounds like a shorted touchpad to me. Can you fix it? I don't know. You will have to disconnect and re-connect quite a few cables and connectors from the control panel. If you've never done that kind of work before, then I would not recommend that you try; it would be all too easy to damage something (like pulling a wire out of a connector, or inserting it wrong.
Oct 18, 2014 | Microwave Ovens
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Touch pad not responding
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Nov 23, 2009 | Whirlpool GH6177XPS Microwave Oven
Keypad does not always work
HI. you will need to replace this malfunctioning key pad asap. this will require you to disassemble the unit, in order to reach the actual touch pad board. It is not an easy task, and i recommend a professional tech, if possible.
Aug 26, 2009 | Maytag MMC5000 Microwave Oven
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
Hello; my oven has been working perfectly. I tried to use the defrost. For doing that I pushed several different pads. Finally with the help of the Owner´s Manual I coudl use the defrost, but the oven is...
It sounds like what you've done is locked up something in the timer. I'd unplug the unit., wait a few minutes and plug it back in. If that doesn't do it, I'd look at whether your unit has some kind of child's lockout that you may have activated. Not that...we've got to look at more issues.
Dec 31, 2008 | Microwave Ovens
Key Pad only works on some numbers. Others do not respond when pushed
Unplug the unit. Generally, remove the screws inside the door that hold on the faceplate. Inside, it will become rather obvious how to detach the keypad from the main circuit board. Note that some of the screws are longer than others. Carefully unplug the wire loom from the board. Note that these plugs have a small movable section. Flush to the board is lock...up is unlocked. Make sure when you push the loom in that the section is up...then push it down. By the way...before you buy a new part, unplug each connection related to the key panel and reinstall. It may just fix it.
Dec 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Control pad?
FIRST CHECK THE CONTROL PAD, CLEAN THE CONTROL CIRCUIT UNIT.
Sep 23, 2007 | Maytag MMV1153A Microwave Oven
Dacor DCM24 Convection/Microwave Oven Logo
79 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Chris Hall
Chris Hall
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
