Question about Motorola Mobility CLIQ Cell Phone
I have a question mark in m battery icon and it refuses to charge it seems to rely solely on the charger
My Tablet is on charge and the screen icon shows it is charging but the Charge % Icon is staying the same
Try a different battery charger.
Maybe you are using a battery charger of a phone.
They have the same plug but different Amperage.
Usually tablets have more powerful battery charger than phones (2.1A instead of 0.5/1A).
The battery charger that you are currently using seems to have enough power just to keep your tablet alive, but not enough to charge it.
You can check on the data written on the battery charger's body the maximum amperage.
Jul 16, 2016 | Amazon Kindle Fire HDX 7
Hello, well my acer laptop model AO751h doesnt seem to be charging. I check the battery icon and it says "plugged in, charging" but it doesnt seem to be charging cause im sure the battery icon...
is this an older laptop, if so you might just need to replace the battery. or try a different charger before buying a battery. If you need anymore assistance im here
May 20, 2011 | Acer Aspire One AO751h-1211 (LU.S820Y.108)...
I have a gateway laptop Md2614u its been less than two years now and just last year December it stopped charging altogether it relies solely on the charger. If I unplug the charger it says battery low and...
Simoo,
These things do happen. It seems that the battery has given up. You need to replace the battery (an expensive proposition). But there is no choice.
After you replace the battery, look after it by keeping it fully charged. Not charging and using at the same time and also by not draining it totally.
Feb 09, 2011 | Computers & Internet
Why won't my computer charge me nikon s202 camera
The S202 does not include any charging circuitry. The computer connection is solely for transferring your photos and videos, not for charging the battery. You should have received an MH-63 battery charger with your camera, use this to charge the battery.
If you need a charger, you can order one from Nikon at
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213504100
or a third-party charger from
http://www.overstock.com/Electronics/Dolica-Nikon-MH63-Charger/3540127/product.html
Nov 15, 2010 | Cameras
Laptop suddenly stops recharging / recognizing the charger
Here is a manual....mostly replacement parts etc.
http://tim.id.au/laptops/toshiba/satellite%20and%20pro%20220%20440%20460%20470%20480.pdf
Sounds like your battery is shot, bad or discharged or shorted batteries will shut the charging circuit off.
Oct 16, 2009 | Toshiba Satellite Pro 470CDT Notebook
Battery charger won't charge
I'm sorry to say I don't know much about Olympus digital cameras, I've never had one on the bench.
I would take your camera and charger to a shop that sells Olympus batteries try a different battery first, this way you can try it out before you buy and make sure the camera and charger are working ok...
The battery is a Li-Ion, when these get flattened too far they shut down and will refuse to charge, they can sometimes be recovered by using a power supply to lift them but you must be very careful (use a 300ma wall wart at just over the rated voltage of the battery for 10 mins then put it back in the charger) as they can catch fire if over charged, shorted or connected backwards also if its been so flat it refuses to charge its certainly past its best and should be replaced as its likely it will let you down again.
On the other hand it could be the charger, so best to try and check out both before buying anything.
If it happened very suddenly and the battery was still able to run the camera for quite a while I would think a charger problem is more likely, if the battery has been taking less time to charge recently and lasting shorter times its more likely the battery..
Having said that the protection circuits can shut down a seemingly good battery for other reasons.
If you find its the charger third party (non Olimpus) chargers are available quite cheaply on ebay as are batteries
Best of luck
Jun 14, 2008 | Cameras
My Upstage is refusing to charge all of a sudden
normaly you must use a default charger, it can be that your phone or the battery is damaged.
Jun 12, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Dell Dj 5 will not hold a charge
FYI, replacing the battery did not solve the problem of the battery refusing to charge. Instead, I've spent $30 at batteryship.com and since I've opened the battery I can't return it. There must be a software or hardware failure that's preventing the unit from charging the battery.
Mar 12, 2008 | Dell Pocket DJ MP3 Player
Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (customelectronics.org)
Feb 11, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
CD1000 won't turn on
I am not a techo but if your camera works when it's plugged into the charger but not when just relying solely on the battery, I'd reckon the battery is your problem. It doesn't seem to be holding charge.
Sep 13, 2005 | Sony Mavica MVC-CD1000 Digital Camera
Motorola Mobility CLIQ Cell Phone Logo
159 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
