Question about Sony KDL52NX800 52 in. TV
I have Sony LCD KDL-52NX800. The screen got noise and went black and finally after sometimes, Tv turned off and red light start blinking 5 times each thre seconds.
mistersony
  • 320 Answers
SOURCE: I have a Sony KDL-40V2500 LCD 1080P TV there is no picture the
A 4 flash shutdown indicates a backlight problem. It can be acused by a bad backlight inverter board (the backlight power supply) or by a defective backlight in the panel. There are fuses on the backlight inverter board called "picofuses" which will need to be checked in order to isolate the problem to the board or the panel. If the fuses are good, you have to replace the panel (very expensive!). If the fuses are opne, most likely the back light inverter board has failed.
Posted on Nov 26, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
Please count Sony KDL-46V3000 standby light blinks as there would be interval of 3 seconds between blinks. Let me know how many times light blinks as its an error code.
Posted on May 17, 2009
  • 668 Answers
SOURCE: sony kdl-40xbr lcd tv.. turns on for a second then
I am pretty sure this is a Back Light failure or a bad Ballast. If it is the only fix is to replace the LCD Panel. I would contact Sony at 1800-222-Sony and see if the could help you with repairs and also to get a Factory Service Facility near you to confirm the problem.
Hope this helps,
Skyassoc
Posted on Oct 23, 2009
  • 49 Answers
SOURCE: sony 46 KDL 46S2000 screen went black and the
you can referen the article:
How to Fix a Black Screen at Startup
maybe it can give your some help
Posted on Mar 05, 2010
  • 418 Answers
SOURCE: sony kdl-40s2000 won't stay on and blink red 4 times
That error says backlight failure. It has to be troubleshooted to find out why.
Posted on Apr 20, 2010
Sony Bravia KDL-60EX500 no longer turns on.
Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom...
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
see schematics in Sony KDL 55EX500 Troubleshooting Manual Page 23
Sep 15, 2016 | Sony Bravia Kdl-60ex500 60" Inch 120hz...
Hey so my sony Bravia LCD 55" TV if blinking a red light 5 times and won't turn on...... any idea what I need to fix and how? Oh model # kdl-55ex640
HI
if your modal no is KDL-55EX640 & red light is blinking 5 times then your led panel is defective so please change your led panel in this case
Apr 09, 2015 | Sony Televison & Video
Red flashes 6 times and pause for three secs
Using the remote, open the system menu and reset the tv.
Mar 07, 2015 | Sony Bravia Kdl-55ex500 55 Tv, Series Lcd...
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
Sony KDL32CX520 red light blink 5 times
IKR Error at power on 05. 5 blinks denotes this. Actually, the fault is related to its main digital board, and the work will not an easy one. Anyway, http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or view it in Timslide option, and see whether there is something to help you. If you're not sound in electronics, no need to proceed. Contact any service technician or authorized service centre for Sony.
Jun 29, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
My TV screen went black and now the bottom light that is usually green, now blinks red 5 times in a row. Can you please tell me what is wrong w/ it?
5 times red standby light blinking shows problem with ballast supply board in Sony KDF-E50A10 model tv, ballast supply board provides high voltage to lamp to produce high bright light.
Please check/ replace ballast supply board in tv by local tv repairman.
Thanks.
Nov 07, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KDL52NX800 52 in. TV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
