Question about Sport & Outdoor - Others
What is the oil-fuel mixture ratio for the Ryobi 700r grass trimmer?
    Scholar:
  • 71 Answers
33:1 to 40:1 is typical on about 95% of all line trimmers. I own (2) 700r's and one is 32:1 and the other is 40:1, you won't go wrong at 35:1 with current 2-cycle oil. Suggest using low-smoke brands.
Posted on Sep 25, 2010
What is the problem?this ryobi ss26 weed trimmer gets fuel and spark but yet will not start
Is the fuel the correct type. Most weed trimmers use mixed fuels and they must be the correct mixture ratio of gasoline and 2-cycle oil. Some are 16 to 1, some are 30 to 1, some are 40 to 1. Check your manual or on the unit for the correct mixture ratio. If that is correct, and you are getting fuel and spark, the only other thing that would affect it would be a mechanical problem such as low compression due to using fuel with not enough oil causing premature wear. Best Wishes
Sep 01, 2014 | Garden
Two stroke ratio calculator
If you are referring to the fuel mixture, it is 50:1. So for one gallon of gas, use 2.56 oz. ( US measure) of two stroke oil. Gas Oil Mixture Ratio Calculator
Jun 30, 2014 | Garden
What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
Oct 03, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Nov 27, 2010 | Ryobi Garden
I need to know the fuel-oil ratio/mix for my Ryobi 700r String grass trimmer.
Start with 40:1. If it smokes, go to 50:1. Good luck...Lee
Aug 29, 2010 | Ryobi Garden
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
I have a 25cc Ryobi grass trimmer I have lost the manual. I would like the fuel ratio of petrol to 2 stroke for this trimmer
http://odref.com/pdf/Ryobi/
If you have your model number, an owners manual should be here with correct mixture ratio for petro to 2 stroke oil.
Sep 14, 2009 | Ryobi Garden
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Dec 10, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Sport & Outdoor - Others Logo
112 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
