Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine is turning clothes orange, im guessing due to well water. detergent tray is orange. can this be solved?
    Champion:
  • 274 Answers
It sounds like iron stains, install a iron filter on the inline hoses ,add a water nonprecipitating water conditioner.
Posted on Aug 29, 2010
I have a Kenmore series 600 washer which leaves white residue on laundry. I've tried using less detergent (only use liquid detergent) but it still happens. Using Tide detergent.
There are a lot of causes for that issue. Overloading, too much softener, bad drain pump, dirty drum, hard water are some of the more common ones.
Jan 11, 2017 | Kenmore Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
Ultimate Care II top loader washing - rinse issues
New concentrated powdered detergent takes very warm water to break it down. As for most dark clothes use cold water. I have one of these top loaders and for my cold wash colored clothes I use a liquid detergent and have no problem.
May 06, 2010 | Whirlpool LSQ8000 Top Load Washer
Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
Sep 09, 2009 | LG Washing Machines
My maytag neptune is not getting clothes clean
SPOT COULD BE DETERGENT OR SOFTNER IF YOU USE IT- TRY DISOLVING DETERGENT IN WARM WATER BEFORE ADDING IT TO THE MACHINE- THIS WILL TELL YOU IF IT IS THE FAULT.
INSUFFIENT WATER WILL ALSO CAUSE THIS PROBLEM. SO WILL OVERLOADING
Jul 08, 2009 | Washing Machines
Water and detergent are in the bin after wash cycle
check to make sure water lines are not clogged and detergent tray is not caked up
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
After washing clothes, water stays in the detergent tray.
Best plan is probably to take the detergent tray right out of the machine, then take it to bits before washing it out with hot running water and a toothbrush.
The problem with these things is that the bit that blocks up is pretty well hidden until you dismantle the tray.
A.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water is pouring out of deteregent tray on fill up
inside the washing machine there drain from the detergent tray to the washer, it is plugged by a piece of clothing. remove the clothing and all should be fine.
Jan 01, 2009 | Kenmore 43142 Front Load Washer
SIEMENS XLM 1600 (WXLM166AGB) MACHINE WILL NOT TAKE IN SOFTENER FROM DETERGENT TRAY
If water is being dispensed from both sides of the detergent tray, dismantle washing machine and remove top plate of the detergent tray and clean thoroughly. Water overflows from both sides during the rinse cycle to add softener to the rinse. On our washing machine it was blocked. During the service it was changed but can be washed out to solve problem.
Aug 28, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
163 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
