Question about MSI K7N2 (MS-6570) Motherboard
How do I reset the cmos settings for the msi motherboard ms 6570?
I accidentally changed something to start in agp and can't get video or a hard drive crunch anymore..... I was overclocking and accidentally hit a wrong key..... oops!!!!
    Sergeant:
    Champion:
  • 304 Answers
If you're unable to enter your BIOS, or if you set a system password in the BIOS but forgot it, you might be able to fix the problem by clearing the CMOS memory. On some motherboards, this requires you to turn off and unplug your PC, disconnect the CMOS battery for a few hours, replace the battery, and turn on your PC again. Other motherboards have a CMOS clear jumper pin that you must move to a temporary position and then return it to its original position.
Post back if you still need more help.
Thank you
Posted on May 07, 2008
Bios reset on ms 6570 k7n2 delta ilsr with jumper
Hi, you can download a manual here:
http://www.msi.com/product/mb/K7N2-Delta2-Platinum.html#/?div=Manual
Unzip the file before you can read it.
The bios can also be resetet by removing the cmos battery:
The manual shows how to do it with the jumper settings.
Sep 25, 2011 | MSI K7N2 (MS-6570) Motherboard
I have a MSI MS-6566 Ultra-C v1 with an Intel 2.6MHz CPU. The board is getting power and the CPU fan is running along with the fan on the AGP video card, but the CMOS will not post. The PSU tests fine. ...
have a problem with v1.5 a6566ims always ask if in start setting bios date month and year, and the second when the computer restarted there was no display on the monitor even though I have changed battere, VGA or memory, whether the BIOS has been damaged? what should i do please help. thanks
Aug 31, 2010 | MSI 845 Ultra-C Motherboard
AGP Card MSI MS-StarForce GeForce FX 5200 undetected.
for agp motherboards, you have to install agp mobo drivers, before you install the actual video card drivers.
May 25, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
New sata hard drive fitted, now says no audio deviec ,so no sound
If you just added the sata and reformatted the drive with a new copy of the Operating System you will need to reload the sound drivers located at MSI's web site in there drivers and download section.
May 22, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
My server would not start up after I removed the CMOS Battery
There is a capacitor in switching power supplies that fails, and is only used to start the supply, so with that cap bad it will keep working until you turn it off and then try to start it again. Apparently that's where you're at. Replace the supply.
Apr 27, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Need drivers for the motherboard
Here you go:
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=519
If this isn't it just search MSI.com and leave off the MS 6570. There were a couple of different ones.
Let me know if that helps you.
Mar 17, 2009 | MSI K7N2 (MS-6570) Motherboard
Audio sound
install the AC97 drivers from Realtek and than go to your sound mixer and open the volume
start
control panel
sounds
advanced settings in left corner
unmute all
move all levers up
and you will have sound
Apr 25, 2008 | MSI K7N2 Delta-ILSR (MS-6570-030)...
I tried to overclock it
Doesnt sound good - When you said you reset the bios that meant you reset the CMOS jumper on the mainboard?
If that doesnt do it then i would try just one stick of ram at a time.
You may even have burned up the CPU trying to overclock it so far. If you could find another athlon xp then i would try that last.
If that isnt practical then it is likely the mainboard is shot.
It would probably be best at that point to use this as an excuse to upgrade to a newer platform - an athlon x2 5600 with mainboard and RAM is only about $200-$250 depending on the combo you get. Keep in mind most newer boards will use PCI Express instead of AGP video cards.
Dec 20, 2007 | MSI K7N2 (MS-6570) Motherboard
MSI K7N2 (MS-6570) Motherboard Logo
963 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
