Projector image going out
I have a samsung projector(model SP-H710AE) which I have owned for about a year. I recently began experiencing problems where the image on the screen goes out but the machine is still on as if it is functioning properly. The temp. light does not come on, and the fans still sound fine. It is dire for me to get this machine working. Can u please help???
  • 563 Answers
Hi DHova
This is most probably your lamp that is the cause of the problem.
Take out the lamp and check for any markings or discolouration or even a bubble at the end of the shaft. In which case the lamp will need replacement.
I'm sure this will be of help.
Posted on May 08, 2008
Habe einen samsung dlp beamer SP-H710ae. Beim Einschalten leuchtet die "stand by" Anzeige, die Anzeige "lamp" blinkt, nach kurzer Zeit leuchtet die "temp" Anzeige. Kein Bild. Ein Austausch der Beamer-Lampe...
ist der beamer nog innerhalb garantie, dan bitte zuruck zur lieferanten, am sonsten kan mann versuchen die kappen weg zu holen und die ganze sache von innen aus mal richtig zu sauberen, staub kann die sensoren storen, weicher pinsel und staubsauger konnen helfen.
viel gluck
Aug 17, 2013 | Samsung Office Equipment & Supplies
How to display Monitor image from mac book through samsung SP-H03 pico projector?
It's not that easy. The SP-H03 accept VGA input through the D-Sub connector. Mac book does not have this output directly. So you need another piece of adapter for the MAC Book to provide VGA output. It would come out from your Mac "Display Port /orThunderbolt port".
Another way is to use a USB to VGA adapter for Mac.
Jan 18, 2013 | Samsung SP-H03 LED DLP Pico Projector
Recently, out of the blue, my HC1600 projector has been failing to project any image. It makes a clicking noise...then stops...makes another clicking noise and proceeds to flash a green and (stationary)...
Probably a power supply problem. Most likely, there is a power transistor or relay that is not properly powering the light or other equipment. Check the warranty on the device, get a new one if you can. It won't be easy to fix.
May 03, 2011 | Mitsubishi HC1600 Projector
I recently had my lamp go out for the Infocus SP 4805 projector. When I replaced the lamp, the projection/imapges had discoloration in a couple of spots on the screen. not completely black, but discolored....
If you have not already found out, your problem may be a Light Tunnel Failure. It is common and can be corrected DIY. Replacement part is nearly non-existent and manufacturer repair is expensive.
For additional info go to www.avsforum.com and search for "4805 Light Tunnel". You will find threads about the problem as well as fixes. I also posted a DIY replacement option as well:
www.avsforum.com/avs-vb/showthread.php?t=1304694
Sep 13, 2010 | InFocus ScreenPlay 4805 Multimedia...
Want to change lamp
after you remove the door, the lamp assembly should be right ther with the little wire handle. unscrew the 3 screws and pull the lamp out. if none of that is there, you have no lamp to replace.
Sep 22, 2009 | Samsung Sp-H710AE Multimedia Projector
Out of focus
You have a convergence problem, probably the convergence electronics are going out or the TV has been violently moved and needs a mechanical alighnment. Small adjustments can be made from the menu.
May 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Lamp shutss off after about a minuet or so..
Sounds a lot like a heat problem; the unit may not be running hot but there may be a bimetal thermal switch that has become fussy.
If you have an electronics supply nearby, they will have 'freeze spray' and if you procure it, you can see if the projector will turn back on if you give it a shot in a vent. Do NOT spray it on a hot lamp; it may cause it to fracture.
I would also keep it out of the reach of kids since it can impart a nasty 'burn' if misused.
If this does make it turn back on, you will have to come back and seek help in locating the failing switch although the common ones are disc-shaped with two contacts coming from them.
This construction is failing in 100s of thousands of drip coffee makers too.
Sep 19, 2008 | Samsung Sp-H710AE Multimedia Projector
Startup issue
Either the lamp needs to be replaced, or your projector is experiencing overheating problems.
The unit may not be running hot but there may be a bimetal thermal switch that has become fussy.
If you have an electronics supply nearby, they will have 'freeze spray' and if you procure it, you can see if the projector will turn back on if you give it a shot in a vent. Do NOT spray it on a hot lamp; it may cause it to fracture. If this does make it turn back on, you will have to locate the failing switch although the common ones are disc-shaped with two contacts coming from them.
May 28, 2008 | Samsung Sp-H710AE Multimedia Projector
InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Mar 11, 2008 | InFocus Lamp Projector Lamp for LP240 [...
192 people viewed this question
jasbo
jasbo
