Question about Sony Mavica MVC-FD7 Digital Camera
Powers on then lcd screen shows disc error ; c:13:01
After camera powers on the lcd screen shows DISC ERROR .upper rt. corner shows c:13:01 flashing. THANKS W.R.Cagle email wrdc6b@infowest.com
  • gobgramps May 07, 2008
    this is for sony mavica fd7
    Scholar:
  • 97 Answers
I had the same issue i have a couple of thease i use for parts the drive error will be 1 of 2 things 1 a bad floppy 2 the floppy drive is bad i had to take one apart and swap the drive out witch fixed the issue on the other note ther cheep on ebay so i'm trying to hack it to install a SD card insted just to see if it will work good luck
Posted on Aug 30, 2010
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Z1275 view screen partial closed upper left corner shows a small area I
In order to answer your quarry.
Please explain exactly what you see on the LCD and what effect it has on the use of the camera.
Dec 09, 2009 | Kodak EasyShare Z1275 Digital Camera
My Sharp Aquos blue ray player won't read all blue ray dvd's, why
You need to force the player to the the Top Menu of the disc.
The way to do this is: load disc, wait until it says "Reading Completed" (about 1 minute).
Wait for the PLAY icon ">" to show in the upper right corner (this may take up to 30-40 secs).
Once you see the ">" Hit the STOP button on the remote to get to the player's splash screen.
From the Sharp splash screen Hit the "Top Menu/Title List" button on the remote and wait for the circulating dots and then the disc menu appears.
Play the movie from the menu and you should be good to go.
~JC
Jul 16, 2009 | Sharp BDHP20U Blu-Ray Player
Black screen with flashing small line in upper left corner
PULL OUT THE MEMORY AND PUT THE OLD ONE BACK IN AND SEE IF YOU FIX THE PROBLEM.
Feb 12, 2009 | HP Compaq d530 SFF PC Desktop
Flash will not atomatically flash/can't change flash setting
Do you see any flash error code on lcd screen? if no then...
Flash will work when camera will set on auto mode ( green mark on jog dial) and you will see flash icon on lcd screen.
Dec 12, 2008 | Cameras
A red image pops up when I take a pic
I chose the DMC-TZ3A since I didn't know what the letter was at the end of the model number for your particular camera. If this is the camera
Here is a link to the manual
If not
Here is link to the Lumix series cameras
Pg 25 indicates that flashing red in the upper right corner is the battery needing to be recharged. If the battery was recently recharge and its turning red on the screen, it could be that the battery isn't holding a charge and may need to be replaced.
I didn't see any other error messages on the screen indicating that icon unless b,c, or d models have a different error message in that area of the screen.
Jul 11, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Help flash Nixon coolpix L11
hello,
make sure when you press the round selection button on the back of the camera flash option, you press the ok in the center of the button on the back.
it will show brief yellow AUTO in the LCD screen upper right corner for a sec.
when you are going to take a picture holding the shutter button half way down, you should see up at the right corner outside of the LCD screen a red led flashing to indicate flash is ready.
one thing to try if this is not working, find the camera reset option in the menu. after doing this you may have to reset the date & time. it will bring the camera back to default settings
on the bad side if these dont work, possible flash circuit may have failed inside the camera.
good luck!
Jun 13, 2008 | Nikon Coolpix L11 Digital Camera
Wierd image
This is a "histogram" showing you some information about the brightness levels of the photo. You can press the "DISP" button to toggle between three views -- full details(what you are seeing now), limited details, and no details.
Feb 15, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Sony Mavica MVC-FD7 Digital Camera Logo
172 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
