Loaded drive but no icon or able to run program. I tried two differenct usb ports
  • 43 Answers
Plug the drive into the USB port
take device manager and check if the device is detected by the Operating system.if not it may be damaged
Posted on Aug 29, 2010
Asus laptop with Win7 64 bit asks to format WD external drive while other laptops have no issue running it - how come?
you are not swapping from mAC to PC and back , right?
try other USB ports.
many external drives do not run with out an external power pack.
elements, use 4 diffr. 18watt power packs, Are you using the right one?
so plug that in ,first. then plug in USB , w7 must go Ding dong
or the USB is DEAD. (use this as #1 fact to follow)
then put ear to the case of drive, hear it spin?
if not ,there is no power, for SURE.
solve that first.
ok, it spins. (soft whirl\'g sound, do this when new to memorize how GOOD sounds)
for a tests, leave the USB cable , not connected.
let w7 boot to the desktop.
now plug in the USB HDD, cable.
W7 goes, Ding dong.
then see the USB icon in the tray, does it see the drive>?
Y/n?
click on that tray icon, i see USB to ATPI bridge then...
My externals (have many) shows as Z:/external below , bridge....
if not , USB is failing.
yes, ding dong, yes Icon, yes see drive above.!
then go to disk manager, type those 2 words in the run box.
start +run " disk manager"
CP(controlpanel)+computer management +disk management.
does disk manager see this spinning drive.
mine shows,. DISK 2 and is letter coded Z:
if not , the USB port is not working. or the drive is not with power.
if disk manager shows the drive, the assign a letter to said drive
now program manager can see the drive, with this letter Z.
it dont need to be Z , per ce\' but that letter is a nice flag.
step by step.
oops it has green tech, that means it goes to sleep.
make sure you turn that off first. or it may not show up at all.
it\'s so green its , invisible?
wd on their DL page has a spin down utility, use that.
Oct 03, 2013 | Western Digital Elements 2 TB USB 2.0...
How to unlock partition on flash drive
USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link Below). http://www.truecrypt.org/downloads Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed.
Hope this helps.
Jan 17, 2013 | SanDisk Electronics - Others
I can't open because of the paSSWORD IN IT.
Hope this helps.
Jan 17, 2013 | SanDisk 2GB microSD Memory Card
Un lock my pasword
Which is it a 2 gb cruzer or 1000 gb ??
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link in Resources). Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed. Hope this helps
Dec 20, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you use usb sticks?
1. Plug thumb drive or USB into the USB port on the laptop.
2. Go to My computer and see if you see "Removable Disk" if yes then you double click here and you will see the contents of the USB drive.
3. load something from the laptop or PC to the usb just drag document or program from PC drive to usb drive.
4.Go to site called "Ehow" to gain more information.
Note of caution donot just pull USB from the usb port it will erase all the information and the USB drive will then be rendered usless.
5. Remove USB in the proper manner that is goto the "task bar and look for the "safe to remove hardware" icon or go to the "my computer" icon select the "removable disk" icon ( right click) and the select "eject" if the drive is busy or a message comes up that it is then closed all programs associated to it and the "Eject" the drive and remove it from the USB port.
I hope this helps. Have a good day!
Jul 09, 2010 | Dell Studio 1737 Laptop
What do micro cruzer sandiscs do
your micro cruzer sandisk can perform lots of function .
You can copy your data,songs, video files on your flash drive to use it any time any where .You can do this by just following the simple steps :
1. Plug the USB flash drive to a USB port.
2. A USB flash drive icon will appear on the desktop
3. Double-click on your Cruzer USB flash drive.
4. Select the files or folders you want to copy to the USB drive by clicking on them.
5. Drag and drop the selected files or folders to the USB flash drive icon.
Note : Do not immediately remove your drive from the USB port,right click on drive icon in notification area then click on safely remove the drive ,then remove your drive from your computer.
2: You can take backup of your computer on your flash drive
3.You can also boot from your drive if *********** board support boot from from your flash drive.
May 18, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Photo viewer device not found
I got a key ring for Christmas too ...when the keyring is on 'charge' mode it doesnt show on computer ...you have to remove the lead from key ring, switch off key ring then replace lead and switch to 'update' mode. Now if you double click on icon it should work!!!
Nov 22, 2009 | Fuji Electronics - Others
Scandisk Cruzer has loaded but can't be seen in My Computer
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer locks up my computer when i plug it in.
maybe the flashdrive is infrected witha virus or something
try to format it
Nov 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
