Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Washing machine while in the spin cycle sounds of balance very loud
6812 N Willow Ave Tampa, FL 33604
I had this problem and replaced the tub seal under the agitator which solved the problem.
Posted on Sep 16, 2008
WASHER SPINS LIKE ITS OUT OF BALANCE ALL THE TIME
Rex, probable broken balancing springs. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Washer Top Loader Out of Balance Shaking Repair Tutorial
http://forum.appliancepartspros.com/washer-repair/6812-spin-cycle-badly-out-balance.html
How to Fix Shaking Washing Machine
How To Fix And Stabilize An Unbalanced Washing Machine
Mar 09, 2016 | Washing Machines
What could be the cause of loud thumping during spin?
Sounds like one of the balancing springs either broke or came off.
Feb 02, 2016 | Speed Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Spin cycle loud vibration problems on spin cycle
What is the complete model number of your unit?
Dec 04, 2012 | Washing Machines
Whirlpool washer WTW6400SW very loud spin cycle, sounds like airplane taking off
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
Jul 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Spin cycle of my duet washe3r is very loud
are you sure your machine is balanced and installed on a sturdy foundation?
May 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 20, 2009 | Kenmore Washing Machines
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
81 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
