I HAVE A LAARS ENDURANCE BOILER/WATER HEATER THE HEAT IS ALWAYS ON. I EVEN TOOK THE LUXPRO THERM OFF THE WALL AND IT KEEPS RUNNING , I HAVE TO SHUT THE BOILER OFF .
5 Suggested Answers
  • 990 Answers
SOURCE: Ihave aTeledyne Laars mini therm jvt
You ether have an internal by-pass or an external one. If you have an external one you need to close it up to 80-90 persent. This will allow some water to go past the heater but most will go through it. If it is open too much the water will offer enough pressure to start the heater but if it doesn't flow through it. It will boil the water inside it and gurgeling and pounding as the water expands. If you have a problem with your internal by-pass you will get the same result but it is harder to fix. This is a disc mounted on a shaft held closed by a spring inside your water manifold on the heater. If you open the header you can get access to the by-pass and may be able to sand the shaft down or if the disc is broken you can replace it. Hope this helps and good luck.
Posted on Dec 20, 2009
SOURCE: have a problem with a laars mini therm ii boiler. the pilot keeps
hi. i have mini temp boiler 150 btu 5yers old . it is burning with know radiation .it is up to thempitio .but it will not shut off.flame is good radietor is hot ,help?
Posted on Jan 05, 2010
  • 82 Answers
SOURCE: have a problem with a laars boiler the pilot keeps
How long does it stay lit (if at all)? It sounds like the thermocoupler (about 10 bucks). Good luck
SOURCE: Laars Endurance ebp have hot water but not heat
check the valve actuator honeywell zone valv
Posted on Dec 02, 2010
I need to reset my mini therm. The wwsd light is on and the water will not heat up more than 140. I need to operate it less the outside controle.
It's possible your outdoor sensor is defective. Part number E2347400. In theory, the WWSD LED flashes for outdoor sensor errors. It's intended to limit the system heat output when the outdoor temp exceeds 70F.
According to the Laars Mini-therm manual for models JVS and JVH, you can use DIP switch setting 3 to modify how the boiler works with the Warm Weather Shut Down (WWSD) outdoor sensor. If you turn off number 3, it inactivates the 70-degree WWSD. This should have no effect upon a call for domestic hot water, but may allow a call for space heat to be processed at the min setpoint of 150, if not the higher calculated setpoint.
The control access panel requires tools to remove the cover, to find the DIP switches, meaning it is not ordinarily intended for use by untrained operators.
Call a repairman to verify what you should be doing to bypass a malfunction temporarily, until they can get to you.
http://www.laars.com/images/uploads/products/1254C-NH.pdf
Jan 02, 2018 | Water Water Heaters
Armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Dec 02, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
May 15, 2010 | Heating & Cooling
Flame shooting out the front of boiler
You will need to remove your burner tray and clean the burners and make sure their are no rat nests. While you have it out clean the gas orfaces in the main pipe goeing to each burner.
You should probally tear down the top of the heater and clean the heat exchanger at the same time. When doing this don't use wire brush as the soot can explode with just a small spark. With the heater tray out you can use water abn a stiff brush to do this. Then let dry while you clean the burners and when you should be ready to go by the time your done but it would be best to wait a day for the heat wall to dry so you don't get popping when the heat hits it.
Good luck and don't forget to do this each year at the start of the heat season.
Feb 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Have a problem with a laars boiler the pilot keeps
Dec 25, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Ihave aTeledyne Laars mini therm jvt boiler(Canadian).When the burner fires up you can hear the water gurgling in the boiler and or volute heat tubes,is this normal? or what is the problem,Low water?and...
Dec 17, 2009 | Garden
Have a problem with a laars mini therm ii boiler. the pilot keeps
Nov 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
