Question about Whirlpool Heating & Cooling
Hi. on my mother-in-laws a/c the fan will run but the compressor will not kick in. could it be a relay or a compassitor gone bad? thank you.
    President:
  • 3,074 Answers
Yes, I would try the capacitor first and also look at the wires that connect to the compressor. Look for a reset button on the front of the unit first as it may just needs to be reset
Posted on Aug 29, 2010
Why wont my A/C Compressor and High Coolant Fans Engage?
Check for broken wiring, blown fuses, possible bad relays, and look at the pressure switch. Some systems have a high pressure switch (some have a low pressure also) that prevent the compressor from running. If it is faulty or damaged, it could be preventing the compressor from running. Wire damage could be possible with front end damage.
Apr 09, 2017 | 2001 Cadillac DeVille
GSS20IETA GE Refrig keeps frosting up every 20 days, Have replaced mother board defrost thermostat, Evaporator Fan Motor, and heat element. It still frost up
I would suspect the mother board even tho it is new because if it burned out to start with
and you didn't replace the part that blew it out then the mother board will do it again.
It could br the relay or the compressor or any number of elect problems
Here is a generic sampling of my ideas.
First I would remove the mother board and look for a burnt or black spot somewhere on either side of the board. I would change the defrost Thermostat again just for fun.(Some times they are bad)
Here is some help
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Refrigerators
Unit runs for about 5 min the cuts off. whats the problem?
Hi!!
It could be many things, the most common are Low R22 refrigerant, bad fan motor, bad compressor. obstructed condenser coil, bad starting relay, bad capacitor. among other things.
To check fan motor, set unit to HI Fan Only setting and let it run for a while, check that fan did not loose speed and it is not getting too hot.
If fan is OK, then turn unit to HI Cool 60-65 degrees and see what happens. Hear if compressor kicked in or if just made a humming noise and stopped. if this happens, replace capacitor.
Keep me posted!! Rate this post!!
Aug 14, 2010 | Kenmore 72055 Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Compressor kicking on and off now not anything
Make sure you have 120volts at relay if not jump out thermostat if it starts to run and stays running Replace the thermostat. If you have 120volts at relay and it is not running or it's kicking off and on replace Start Relay/Overload but a bad compressor can make a Start Relay go bad so if you have the same Prob. after replacing Start Relay/Overload Compressor is bad
May 20, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Maytag MSD2758DR side by side, not cooling at all clicking at compressor relays but compressor doesn't kick in . What do I check first?
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 12, 2010 | Maytag MSD2758G Side by Side Refrigerator
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
May 18, 2009 | Frigidaire FRT21H7AS Top Freezer...
Kenmore refrigerator
HI thanks for the question. the relay is on the compressor. but are the fan, motors running. if not , then its not the relay. it could be in the defrost cycle. but if fans are running. yes the relay. thanks the appliance doc. please rate my answer. thanks
Oct 06, 2008 | Kenmore 44109 / 44102 Side by Side...
I have a GE GSS25JEMACC and compressor doesn't kick in... all fans run. Yesterday the defrost cycle thawed the entire freezer full of food. Took back panel off inside freezer, there was no frost or ice...
Hi thanks for the question. if all fans are on . not in defrost cycle. look at the compressor relay. replace the relay. thanks the appliance doc
Oct 06, 2008 | Refrigerators
Heating & Cooling Logo
27 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
