Question about Cameras
The film is stuck, what the ****? - Cameras
    Brigadier General:
  • 11,967 Answers
You've given us no information about your camera so we can't help you.
Posted on Aug 29, 2010
Film stuck in on right hand side
First, be sure you've pushed the film release button (usually located on the bottom of older film cameras) and then try rewinding. If the film is stuck on the take-up reel of your camera your best bet is to manually unwind the film from the reel and see if it will work properly again. If not then it wasn't a film problem but a mechanical one on the reel.
Feb 15, 2014 | Canon Photography
Film advance lever stuck
Do you have a film in the camera? If so is it all exposed? Best thing to do is press the film rewind button and try the lever at the same time - this will eliminate stuck film issues as it removes film tension from the system. If this does not solve the issue then you need someone to have a closer look.
Feb 07, 2014 | Canon F1-N 35mm SLR Camera
Film is stuck
Film stuck is cause by faulty gear. camera most like had been dropped. gear is damaged.
Jul 28, 2013 | FUJIFILM Instax 210 Film Camera
The Film advance lever is stuck, how can I fix this?
This camera is 42 years old. Sounds like a mechanical problem, but I doubt you are going to find any company or individual who knows how to fix it, or can find parts for it, if needed.
Suggest you keep this museum piece as a conversation starter, and invest in a newer model.
If you want to stay with Canon, the Elan 7N and Rebel T2 film cameras are 'only' about 13 years old. I see Elans on eBay starting at $70 (body only).
Jul 04, 2017 | Photography
Film roll stuck in my camera canon eos lx
The Canon EOS is a digital line of cameras from what I can tell. If that is the case, then there is no film in the camera.
However, assuming that you actually have a 35mm camera with film stuck in it, the following should work for. You don't indicate what you mean by stuck, but the standard solution for removing 35mm film from a camera is to take the camera into a dark room, open the back of the camera and remove the film and canister, being careful to not tear the film. While still in the dark room, place the film into a light proof bag to avoid spoiling it when it goes into the light. You can then contact a local photo processor about their ability to process the loose film. Make sure that the bag is clearly marked to avoid having someone open it by accident, spoiling the film in the light. If you can't find someone locally who can process the film, Kodak can do it for you in Rochester, New York. Contact them for instructions on shipping the film.
If you don't care about the film or pictures it may contain, feel free to simply open the camera and remove the cansiter and film, discard it, and start over.
Nov 14, 2010 | Canon Photography
The film magazine stuck in the Canone EOS 10 camera, never happened that before, i could easily insert and remove the film. it's rewinded, luckily, but I need a new one to put there, + I'm afraid if I...
Nikon N75 or Canon EOS 10????????
How is the film stuck? Is the rear door stuck? Does the film door open?
As long as you do not damage the film canister, the film will be ok. If the door opens and the film is rewound, use something to pry out the top of the canister from the camera. Then you can remove the film.
Even a film roll of 36 should not get stuck. Check the cartridge are for anything sticky. Sometimes these older cameras get some sticky residue from decaying foam in the shutter area. This would be a good time to send it in for CLA - Clean, Lubricate, Adjust.
My own EOS 10 had that problem. If you can't get the film out, the repair shop will do that for you.
Jan 20, 2010 | Nikon N75 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
SA-21will not pull film strip into chamber
Put the film in after it is powered up. The unit needs to run through a power-up and calibrate cycle first. Once powered up, the until will feed the film in once it reaches a certain point into the machine.
The unit is supposed to kick the film back out when you close down the scanning software. If your film ever gets stuck try this to get it out. DO NOT force the SA-21 out of the machine with film stuck in it.
Aug 13, 2008 | Nikon COOLSCAN IV ED LS40
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
