Question about Toshiba Satellite Pro L300 Notebook
My laptop randomly pushes buttons from my keyboard. When I turn My Toshiba Satellite L300 on it starts pushing buttons. So I'm kind of afraid to turn it off again because last time I did it, I couldn't get past the Setup Utility because the laptop constantly pushed the F2 button. But the "-button and the !-button or also one of it's favourites. How do I fix this? Or should I bring it back to the store where I bought it?
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
If it is still within warranty, then take it back to the store. If not, you are better off finding a tech savvy person and have that person take the computer keyboard apart and clean it properly so the keys don't stick and actually lets go.
If you have spilled anything sticky in it or used it with sticky fingers, it will most likely be the reasons for it to happen and in that case you have voided the warranty.
Posted on Jul 16, 2017
5 Suggested Answers
  • 674 Answers
SOURCE: i download BIOS from the net on my toshiba satellite L300
upgrading bios is dangerous.. in not complate or accedentaly restart. system will not work...
Posted on Sep 09, 2009
  • 4806 Answers
SOURCE: Toshiba Satellite A75-S209 (PSA70U-09700E) PC
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Posted on Nov 13, 2009
  • 194 Answers
SOURCE: Toshiba satellite L300 freez...
Hi the problem sound familier, Firstly unplug all the USB devices from the notebook and remove the battery and the power cable and press and hold the power button for 10 sec and then remove the memory from the notebook one by one if there is more then one and reset it agian and try to connect the notebook on power cord and check. let me know about it.
Posted on Feb 13, 2010
  • 215 Answers
SOURCE: Hello all. I'm in desperate need of some help. ,
Hi,Try doing these,turn the system upside down,the maybe two compartments,unscrew the compartment at the middle locate the RAM Chips two in number,dislodge each one after by pulling the lever at both ends slightly bring them out of the system,now select a slot of your choice and put just one in,power-up the system,if system does not come on,power down,remove RAM put the second one into the Same slot like you did the first,if system does not come on try the second slot.if after all these system still does not come on i will advise you take to qualified service personnel.
Posted on Dec 30, 2010
My toshiba laptop satellite pro L300 one number key 4 and ESC key n/w
You need a replacement keyboard. You can get one from ebay for about $25. Just search for "toshiba satellite pro L300 keyboard" without the quote.
Oct 08, 2010 | Toshiba Satellite Pro L300 Notebook
Several keys are not working on toshiba L300
the problem is from the keyboard. Open the laptop, detach the keyboard from the laptop and clean it. If cleaning does not solve the problem, it means you will have to get another keyboard or use an external keyboard.
Take care.
May 29, 2010 | Toshiba Satellite Pro L300 Notebook
Howdo I remove the keyboard of my Toshiba Satellite Pro L300-19Q
Follow this instruction to remove the keyboard >>>>>
Turn off the laptop, unplug the power adapter and remove the battery.
Insert a small flathead screwdriver under the keyboard bezel and carefully lift the bezel up.
Continue removing the bezel with your fingers.
Remove two screws securing the keyboard.
Push on the plastic tab pointed with an arrow.
Carefully lift up the keyboard and place is so you can access the ribbon cable underneath the keyboard.
Unlock the connector and release the keyboard cable.
Remove the keyboard.
In order to unlock the connector you'll have to move the brown tab about 2 millimeters away from the connector base.
On this picture you see the unlocked connector.
Good luck.
Aug 03, 2009 | Toshiba Computers & Internet
Keyboard description
If you don't have the option on the keyboard to change it, you can change the volume in:
- Start
- All Programs
- Accessories
- Entertainment
- Volume Control
You can also click the sound icon in the bottom right corner of the screen (by the clock)
Mar 07, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite display problem
ur computer is stuck in resume mode and since there are not all the files on harddrive when it went off so what you need to do is this as soon as it powers on at Toshiba screen keep on taping F8 and then select delete restoration data after that it should boot up fine.
Nov 26, 2008 | Toshiba Satellite A60 Notebook
Will not turn on. Toshiba 2060cds
I am having a hard time finding the manual for this older laptop, but, there is always a power button somewhere on the laptop itself, on the side, front, top of the keyboard, push everything and anything till you find it. Just plugging it in will not turn it on.
Apr 06, 2008 | Toshiba Satellite 2060CDS Notebook
Toshiba Satellite Pro L300 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
