Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Steering on cub cadet super lt 1550.....how do you get steering wheel back on
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 1111 Answers
SOURCE: Engine will not start
you have atleast 2 safety switches on there. one under the seat and one one the brake. if either one would fail, the engine will not turn over! i had to replace mine last yr
Posted on Jun 17, 2009
SOURCE: I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Posted on Jul 29, 2009
SOURCE: Cub cadet LTX 1045 steering problem......... Only
Probably a bent "drag link". See your owner's manual about checking for damage adjusting the steering. For the LTX 1045, it is "Maintenance Section 6", Page 22. If it is bent, repair or replace as mowerman1857 indicated.
You should also lubricate at the two grease fittings (per side) shown on Page 20 -Lubrication - "with a #2 weight Multi-purpose grease". It may have been skipped at the factory or may have been stored at high temperature before you got it, and dried out. (Text in quotes are from the manual)
Posted on Nov 01, 2009
Cub cadet. Super lt 1550 not going forward,but goes in reverse
Hopefully linkage problem otherwise could be transmission, if it goes full speed in reverse probably just
linkage.
Sep 19, 2017 | Super Garden
I lost the fuse for the ignition system and I don't know what to replace it with.
a two dollar fuse from auto parts store. or maybe one from scrap yard.
Feb 27, 2016 | Cub Cadet Super Lt-1550 Riding Mower
Cub cadet super LT 1550 will not start. Worked fine when we mower last time, now is dead as a doornail
If you mean that the engine will not turn over when the key is turned, then most likely the battery died over the winter.
Jul 14, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Was running and now its dead
battery dead because the charging system doesnt work ?
blown fuse ?
Dec 14, 2013 | Cub Cadet Super Lt-1550 Riding Mower
Will not start
Some Ride on Mowers have a small electric circuit button under the seat, So if you are not acktually sat on the seat of the machine It will either not run or start, hope this helps
Sep 10, 2013 | Cub Cadet Super Lt-1550 Riding Mower
I need to repair the steering on a Cub Cadet LT 1045 ANY HELP?
there is a plastic coupler the holds the shft to the gear they wear and don't hold the shaft tight to the gear and they jump
Jul 31, 2012 | Cub Cadet Garden
I have a Cub Cadet LT 1042 and the steering wheel just goes round and round.
This sounds similar to the wheel on the bus....<giggle> Well, what you do is look at each part downstream of the steering wheel. Eventually, you will find one part moves and one does not, and that is the area you need to investigate. Often a sheer pin gets sheered.
Jun 03, 2011 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
359 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
