Question about Vacuums
I have the Electrolux Velocity Pet Lover 1800w which has lost all suction from the pipe. I have checked for blockages and cleaned the filter but still no joy. Would changing the HEPA filter resolve the problem? Your help is much appreciated
4 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: I have a velocity pet lover 1900 only 2 months old
You have broken the rubber belt that drives the brush. Flip over and remove the old belt and replace it with a new one.
Jim
Posted on Jun 11, 2009
SOURCE: Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Posted on Jul 21, 2009
  • 175 Answers
SOURCE: hi,my vacumm is blowing air out of the vents .it
Those are the exhaust vents from the motor. It is designed that way to help keep the motor running cool.
Posted on Jan 01, 2010
Electrolux Velocity pet lover 1800W Drive belts keep on breaking...
Dear Judy, there are several things that can cause the problem you are having but I can give you a few things to look at. First is that you are getting the correct belt for your machine. Second is the motor and brush roll moving freely after you install a new belt & before you start vacuuming?. Third is the machine set at it's lowest setting(try a higher setting to start) finally is the belt an after-market made in china one. Quality in Chinese rubber products can suck at times. If all this is ok than it maybe best to take to your local vacuum repair shop. Good Luck-Jack of all trades bob
http://www.habitacionesparalationos.org/
Jan 02, 2017 | Electrolux Vacuums
My vax pet Hoover has lost its suction I've emptied it there's no blockages and Iv cleaned the filter
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction.
Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Jan 09, 2016 | Hoover Vacuums
My electrolux vitesse pet lover 1800w has stopped working
Is the flex all right? Check it with a voltmeter or a continuity meter (available for a small sum in your local hardware or electrical shop).
Jan 19, 2015 | Electrolux Vacuums
Electrolux Vitesse Pet Lover 1800w. I was given this vacuum today. It works fine but is really loud. It's hardly had any use. Is this normal? I just put in ear protection.
Should not be that loud. Check all the filters and see if they are ok. Check to see what the suction level is. This is kind of subjective. IT might have a bad bearing in the motor.
Nov 18, 2013 | Vacuums
Electrolux pet lover loss of suction through the hose
I would use a snake for plumbing (sinks) and feed it down the hose to find and clear this blockage if you can remove the hose compressed air may also work.
Dec 18, 2012 | Vacuums
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
Jim
Jun 10, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Jan 21, 2009 | Electrolux Central Vacuum
Sep 07, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Vacuums Logo
192 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
