FixYa.com
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Whirlpool Gold Microwave Model GH7155XHS
posted by Minnesotaman on May 07, 2008
Whirlpool Gold Microwave Model GH7155XHS over-the-range
Microwave do not heat content. All other functions like light, timer, clock, fan work properly. The turntable turns at 0 power setting but do not turn on 100 or ther power setting.
Comment by Minnesotaman, posted on Jun 17, 2008
Thanks. Microwave heat turns on by moving door up or down in closed position (comes in contact with door switch). How do I create more conact with door latch and the switch?
Comment by Minnesotaman, posted on Jun 30, 2008
Thanks for the comment... I adjusted the switch... but I still have to move door (very slightly) up or down or little pull back in order for heat to turn on. Need your help. thanks
Comment by Minnesotaman, posted on Jul 02, 2008
problem fixed. Really impressed with your help.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 09, 2008
FixYa! (100)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2614 votes
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Comment by MicrowaveSvc, posted on Jun 30, 2008
Did you test the switch?
Did the mini-manual show anything about the adjustment?
Also be sure there's not a broken tab on the switch mount.
Rating Locked! (?) Minnesotaman has rated this solution as FixYa!
This Problem Also Relates To: GE JVM1651 Microwave Oven GE JVM1660 1000 Watts Microwave Oven GE JVM3660 1000 Watts Microwave Oven GE JES636WK 700 Watts Microwave Oven GE JVM1190SY/WY/AY/BY Microwave Oven GE JVM1410 Microwave Oven GE JES1384SF Stainless Steel 1100 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Kenmore 62702 / 62709 950 Watts Microwave...
can't figure out what wrong
We have a Kenmore microwave... Answer This...
Microwave Ovens
Our Sharp Microwave Model...
Our Sharp Microwave Model... Answer This...
Microwave Ovens
Model #JES2251SJ02 trips...
Model #JES2251SJ02 trips... Answer This...
Microwave Ovens
MICROWAVE NOT WORKING PROPERLY
turn table dose not turn and... Answer This...
Panasonic NN-SN657S Stainless Steel 1300...
f-82 flashing
kepps flashing f-82 panasonic... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
