Question about Hayward SAND FILTER, PRO SERIES
Fine particals in pool, vacume to waste and still in pool
  • 640 Answers
Below is a link to the users manual for these pool filters. They have a helpful troubleshooting guide that you can follow. It should help you correct this issue and have your filter working properly to clean your pool in no time at all!
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Posted on Sep 01, 2010
While vacuming loses suction, sand filter pressure goes high
That increase is due to the filter loading up with debris. Is the pool unusually dirty? If there is a lot of dirt and silt in the pool use the "waste" setting on your backwash valve while vacuuming.
This allows the water to bypass the filter and go directly out the waste line. Keep an eye on your water level because you will be removing water from the pool and may have to add more.
Jun 30, 2013 | Hayward SAND FILTER, PRO SERIES
Hey i find when im vacuming the dirt i pick up from the bottom of the pool just goes threw the filter and back into the pool, what should i do?
The multi-port valve should be in the WASTE position when vacuuming. Make sure there is enough water in the pool to stay above the skimmer when vacuuming .
Jun 06, 2011 | Hayward SAND FILTER, PRO SERIES
Trying to open pool for my first time....not sure what to turn valves to so water will run into the filter from pool
red valve handles align with flow of water long ways the tail in direction of pipe valves open to open pool generally all Valves open Main drain (floor of pool). Skimmer square hole somewhere on side edge of pool... There could be a third Valve for a seperate Vacuming port (like mine) it can be either its below water line .. On the Round Sand filter theres a Multi port Valve I usually start the Filter in RECIRC mode .. While I net and gather debris then I add floculant leave on recirc two hours . Then Shut ALL down for 12 Hrs while all the algae and debris sinks to bottom . Water will be reasonably clear.. Make sure pools Extra full , And Vacum all on bottom on waste setting
Jun 04, 2011 | Hayward SAND FILTER, PRO SERIES
Should my main drain valve be open or closed?
iuf youre just opening and pools Green ? then Yes you want to pull the algae dust Dwn to bottom.. So you can vacum to waste ..Sand cannot filter algae particles it will just come thru the returns you can view it ...
What does my filter need to be set on before i vacuum my pool
For regular vacumming with these Hayward pool filters, you will use the regular filter setting. If you have a very dirty pool or heavy loads of debris, vacuum on the waste setting so that the debris will bypass the filter and not clog or litter it.
May 21, 2011 | Hayward SAND FILTER, PRO SERIES
Dirty water coming back into pool
There is a spider gasket in the valve that could be broken or torn apart.
To check it seperat the valve at the handle and you will find the gasket
inspect .
The Pool Tech
Jul 05, 2010 | Hayward 1 HP Matrix Pump EC40 Perflex...
What setting should I have my Hayward Sand Filter system on when I am vacumming out my pool?
Your pool filter should be set on "filter" for normal vacuuming. If you have a heavy debris load or an extremely dirty pool, you might want to vacuum with the "waste" setting, if your filter has one.
May 20, 2010 | Hayward SAND FILTER, PRO SERIES
Vacum
First, make sure that you are on the "filter" setting. If you have large debris or an extremely dirty pool, you might want to try the "waste" setting. Also, make sure that your pool filter has been backwashed. You might also want to consider changing your sand if it is only. It could have lost some of its effectiveness. Let me know if you try this and are still having problems.
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
When i run my pump while vacuming, my pool turns green
As in most cases today, pumps and filters are not properly matched. The filter cannot retain such fine algae particles because they are being driven through the sand bed by an over zealous pump. I suggest that you let the dead algae settle to the bottom. top up water and use the vacuum to waste position on m.port valve. Vacuum in such a way that you dont stir up the debris.
Aug 14, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
217 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
