Question about Kenmore Elite 45986 Front Load Washer
Washer won't turn on and a code F DL comes on
I've discovered you hit start and immediately bang on the side of the washer in the center. The front door will lock and it will start. Great way to take out your frustrations with it, anyway.... :) good luck
Posted on Aug 29, 2010
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Washer sometimes will not work and a code comes on f dl what does this mean?
The DL code indicates a problem with the door lock. These washers need to lock the door before they fill with water. Then the door will unlock at the end of the cycle. The problem can be with the lock, the sensor that detects the lock status or the main control unit not receiving the lock message. Sometimes the wiring is the problem with the unit.
When the DL code comes on, can you pull open the door as easily as when you open the washer before starting the machine? If you can, then check if the wiring is sending the appropriate current to the lock. If the power is there, replace the lock. If the door has actually locked, then the problem is with another part of the system. Most washers will have a sheet with the wiring diagram and expected readings inside the machine near then main control board. This is accessed from the back of the machine above the wash tub.
I hope this helps.
Oct 16, 2015 | Whirlpool Washing Machines
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
LIGHTS ON WON'T TURN ON DL CODE
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
see this fix
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A FAULT CODE F 11 AND DL F
it looks as if your having a communication problem between your central control unit and your motor control unit.check wiring connection between these two components.if wiring is ok then you will have determine which of these components is malfunctioning.you can also remove kick plate and remove service manual located on either side at bottom.this should give you some help.
Jun 18, 2007 | KitchenAid KHWS01PMT Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
44 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
