Question about Garden
I have a used Ryobi string trimmer that worked fine until one day it won't start. I changed the plug, gapped it to .030. It won't quite catch when pulling starter rope. I have no manual, no more ideas. Gas mix is fresh.
  • 10,319 Answers
Check inside the fuel tank for rotted out fuel lines. they tend to disintegrate. if good is the air filter plugged up? if so clean the spounge filter with gas and let dry.
Posted on Aug 29, 2010
What is the spark plug gap for a Ryobi string trimmer model RY30550 ?
No need to gap from a new spark plug unless the plug was dropped on the electrode.
May 02, 2014 | Ryobi Garden
Ryobi SS26 trimmer won't fire
Are you using a new plug,sometimes a used plug look's good,but doesn't work.
Jul 08, 2017 | Garden
Have two string trimmers, both hard to start. shindawa homelite 62061 & toro TB21EC. H/L does great job when it starts. Toro won't come up to speed. Have cleaned carbs in both and checked plug
When you say it will not rev up to full speed, that sounds to me like a blockage either in the spak arrester in the muffler outlet, or the exhaust port is blocked, or the muffler itself is blocked.
May 11, 2012 | Toro Garden
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you change the string feeder on a ryobi gas
If your machine is a "bump feed" there should be a knob on the bottom of the string feed.....this is a LEFT HAND thread, so turn it clock wise and it should pop free and unscrew....re-string your cartridge and replace it tightening the knob counterclockwise until it stops....that should do it !!!... ;-D
Jul 10, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
Jul 09, 2010 | Garden
I need spark plug gap on a ryan trimmer Model 264
.030 is what i set my ryan trimmer and have had no issues
Jun 14, 2009 | Ryobi Garden
Spark plug
.027 to .030
Apr 13, 2009 | Ryobi Garden
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
