Question about Canon PowerShot Pro1 Digital Camera
Powershot Pro 1 shutter problem
I have a Canon Pro1. It has taken about 18,000 pictures, and suddenly turned off. I took the camera to authorized Canon service here in Ankara-Turkey. I have been told that it was due to a shutter problem. Their suggested solution was to change the lens, which cost about 250 euro something. I refused their suggestion, and told them that I will take my camera back.
One day later they have informed me that they did a modification in the camera and now it works in between 28-50 mm zoom range, so I cant zoom the lens beyond 50 mm. After receiving my camera in this condition I have shifted to a third party repair shop, where I have learned that the main problem was with flexible cables of shutter system, and after the modification of Canon service now the only repair option is really lens replacement.
When I asked Canon; why they did a modification on my camera without my consent, they have replied like "We did a favor for you, we even did not charge money for this modification, you are free to pass your complaints to anywhere you want"
1- After so called "modification" camera starts to function at lower zoom range.
Hence: shutter mechanism is not totally defective. Problem prevents higher zooms.
2- Third party repair shop claims that, original problem was with flexible cable which connect shutter unit to camera body. Hence It could be repaired without changing the whole lens. And actually, Canon supplies these parts separately for repairs as well.
3- After I reject service offers, they did a modification in the lens and now shutter works in low zoom range but not higher zoom ranges.
Now my questions are;
1- Does whole lens needed to be replaced?
2- Pro 1 has high quality lenses, would you tie their life to a flexible cable so once your cheap cable dies you also trove expensive lens with them?
3- If this is Canon policy of production we should now it before we buy from them.
4- Do they have right to make such modification, and give me a partially working camera which locks itself with a LENS error when you shift zoom higher than 50 mm.
5- Does the authorized Canon services has right to make modifications on cameras without owners consent?
with my kind regards,
Akif Muhtar
    Genius:
  • 1,689 Answers
The whole thing is very complicated. In many of the new technologies, there are mechancal devices with very complicated electronics intigrated with them.
Sometimes you can get different opinions, but until the job is done and proven, it is difficult to know who is really right until everything has been done.
Personaly, If I like the camera, and I cannot find something that good for 250 EU, I would fix it.
Apparantly, the PRO-1 is one of the best small digital cameras that Canon ever made. I personaly own one. I have not taken too many pictures with it. But, when I use it, for the size its performance is impressive.
I ended up buying a small Canon camera that will fit in my shirt pocket to carry around with me. I use the Pro-1 for more serious pictures.
Jerry G.
Posted on Jul 07, 2008
Lens retraction noise in canon powershot pro 1
The lens needs to be dismantled, cleaned and lubricated by a camera specialist, the alternative is a lens that will eventually seize, shutting down the camera.
Apr 08, 2012 | Canon PowerShot Pro1 Digital Camera
Bright pictures in auto
I have the same problem..repair shop wants $75.00 to inspect and report..this $$ would come off payment if you go ahead with repair...
May 24, 2010 | Canon PowerShot Pro1 Digital Camera
Hi.. Can you tell me as to what is the maximum CF memory card that can be used with Canon Powershot Pro1
When this model came out a 1GB card was a large capacity card, so Canon's specifications stop there. I talked with a friend who has used a 4GB card in a Pro 1, and it's possible that it may work with capacities even larger than that. But I think you will be able to use a 4GB without problems.
May 07, 2010 | Canon PowerShot Pro1 Digital Camera
My Canon S2 IS Powershot camera LCD screen turned black
A stuck shutter is another common failure mode for digital cameras, ESPECIALLY for the S2 IS (you should actually complain to Canon at 1-800-OK-CANON. If it is indeed a sticky shutter, they have been fixing this for free). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Hope this saved you $99.
Apr 29, 2010 | Canon PowerShot S2 IS Digital Camera
Bleeping
Do you have your camera set for continuous focus tracking?
Feb 26, 2010 | Canon PowerShot Pro1 Digital Camera
I also have the same problem and I took it to the canon service center. They told me that I have to replace the whole lens kit the problem was with the shutter not closing properly thus overexposing the pictures
Feb 26, 2008 | Canon PowerShot Pro1 Digital Camera
Lens Movement (Retraction)
Sounds like you might have bumped the lens. In for repair is your best bet
Oct 25, 2007 | Canon PowerShot Pro1 Digital Camera
Shutter speed
You can get much information from the EIXF file generated by the camera with each picture. i think you right click on the picture and select properties. Ed
Aug 31, 2005 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot Pro1 Digital Camera Logo
167 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
