Software update lcd tv
Hi would you please tell me if there is a software update for the phillips 30 32 lcd tv 390127 phil32pfl55220 . We have had the tv for 3 months and it has started to bleed the colours together and i have heard that sometimes you can get a software update that might put this right. Many thanks for your time
frank1.
  • 476 Answers
The Philips 32PFL5522D does support firmware upgrades.
Only the digital board can be updated by the user. This is done by downloading the firmware on to a memory card (CF) and inserting into a PCMCIA adaptor. This is then inserted into the CI slot at the back of the TV.
The main TV would have to be updated by a Philips service agent using a COMPAIR device.
However, I don't think the problem you describe is to do with firmware.
You could try altering the following settings:
  • Contrast - 65
  • Sharpness - 2
  • Contrast Plus - OFF
  • NR - ON
  • Colour - approx 50
If this doesn't help, then the problem is most likely caused by a faulty lead between the LCD panel and driver board. This is a common problem with this model, but should not be an expensive repair.
Posted on May 08, 2008
I have a 42" phillips television and need to update the software. how do I do this please
Check the manual that came with the TV or go to the Phillips website.
Oct 20, 2014 | Televison & Video
Phillips tv wont turn
Go to Philips web site, (enter Model number....) then download updated software & drive to update your TV software. It will fix that problem. I just did for my TV (42PF7320A/37).
Here is the link:
Download and save in USB. Stick USB on the TV' USB then updated from there.
Hope, It will work. Good look!
Nov 07, 2013 | Televison & Video
I have installed Window 7 Ultimate on my computer, and i have a Tv tuner card Philips SAA7130 but i don't have software to watch tv. i have installed drivers and my computer recognized it but i still need...
Greetings looking for software drivers for your Phillips Windows 7 tech support team seems to think if you install the tuner that Windows Update will install the driver it also could be had at the optional update section of Windows Update. You can also go to the manufactures site and see if they have the software there under downloads usually under the support links. Click Here thanks for using Fixya! please post a vote for me if this assisted you in any way have a wonderful day. John
Mar 25, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
When i turn on the tv it just shows the Phillips logo and nothing else. the channels don't come on.
Tried tv and cables or satalites boxes unplug,replug it back like about an hour later.The tv will be reset itself back to the factory setting and the those boxes will updated it softwares.The tv should be working again.
Jan 17, 2011 | Philips 42PFL5603D 42 in. LCD HDTV
Just bought Phillips flat screen 32 inch tv. Manual says i can get software update downloaded to flash drive. I cannot find the link to do this. Please advise
If you are experiencing any problems with your brand new tv, it would be best to consult and call the Phillips tech hotline(1-866-771-4018). Do not experiment and try to download a software without any advise of a Phillips technician. For if in any case it causes some problems it will void your warranty and it will fall under "MISUSED"
Sep 09, 2010 | Televison & Video
I have a Phillips LCD tv model #42PF7421D/37. and
I know on the plasma TV's it was a matter of updating or downloading and re-installing the firmware/software for the TV to fix the issue. Go to the following page and if the model you have is indeed a 42PF7421D/37 download the software on the page. Make sure you follow the installation instructions to update the software otherwise the set will become a 150 lb paper weight.
&scy=US&slg=AEN&sct=LCD_TV_SU&cat=TV_CA&grp=SOUND_AND_VISION_GR&session=20091111140139_64.85.227.44&ctn=42PF7421D/37&mid=Link_Software&hlt=Link_Software">Philips Support Page
Nov 11, 2009 | Televison & Video
Phillips 32pf7320 TV - Menu screen won't go away
i have the solution for this problem it is a software update that you have to upload to your tv if you have more questions email me at caypianan@yahoo.com
Jul 06, 2009 | Philips 32PF7320A 32 in. LCD Television
No sound via TV when PC connected
1. Ensure the TV is set to "home" mode in the user menu. If set to "Shop" it will not retain audio settings change
2. verify that the Audio out from the PC is working. Use a set of headphones just to verify
3. Triple check that you have the audio input assigned to the correct HDMI input
4. after doing these if it still doesn't work, I would suspect the Software update had a side affect that phillips is not aware of. Since this function would probably be missed by Phillips software testers, it is highly likely that this is possible. Contact phillips and let them troubleshoot the problem with you. Let them know it happed after you did the update also and let them know that you have verified the audio out from the PC.
May 20, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
Televison & Video Logo
2,103 people viewed this question
Top Televison & Video Experts
