Question about Whirlpool Duet GHW9150P Front Load Washer
Code f 35 is flashing on the washer - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
Flashes sud then F 35 and locks up, tried running it in the rinse cycle but it continues to do the error code.
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Aug 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Maytag F-35 (suds) error code resolved
Maytag Washer F-35 error code ( SUDS) >> Look for a faulty Pressure switch or bad pressure hose.... Problem solved !
on Aug 04, 2010 | Washing Machines
Kenmore Elite model 42934. Problem washer only
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 26, 2010 | Kenmore 42822 Front Load Washer
It flashes F 35 what does it mran
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trap clean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Jul 01, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer goes to suds mode and then flasher f 35
sounds like the wrong soap. are you using H E soap?
Dec 10, 2009 | Washing Machines
WASHER WILL ATTEMPT TO START CYCLE BUT FLASHES CODE F-35 WHAT IS THE PROBLEM
Sep 25, 2009 | Kenmore HE2 Plus Front Load Washer
Washer stops during begginning of cycle with F 35 reading .
May 13, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Kenmore HE3t keeps flashing wash time.Won't start or cancel/pause
Mar 10, 2009 | Kenmore Elite 45986 Front Load Washer
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
