Question about Fisher and Paykel GWL11 Top Load Washer
Won't power on. We have a GWL11 6 years old. began very slight leak from bottom over past few weeks. Just recently control panel won't turn on. unplugged per user manual. Outlet is hot, tested it. adjusted prongs on power cord to help w/contact. All to no avail. Any idea the electrical issue and replacement part cost?
  • sullycna Aug 29, 2010
    When I mean the outlet is hot, I'm talking about the electric power outlet in the wall, not water. Figured the control panel was fried, but curious about cost of the part. Seems only F&Paykel have that info. Any experience or ideas on the control panel cost? Thanks!
    Yes, thank you.
  • Fisher and P... Master
  • 17,130 Answers
I think there are too many issues and might not be able to estimate the cost as there seems to be multiple faults.
In the first place the control panel not switching On is a big problem because unless the control panel works we cannot move up in the program to check the functions for a proper working of the washer.
So if the control panel board is faultly even after there is supply in the unit, I think we have a tough decision to make.
However if there is some connection fault then try to tighten the connections to switch on. the leak can be from the base of the ttub, the hose or the drain pump.
The indication of warm water at the drain is not good as i presume that the drain valve is powered and hot===indicates fault in control board.
So overall I suggest that you must decide after checking cost of a new control panel. If there is damage to tub evaluate one again.
Hope this advice helps
Posted on Aug 29, 2010
  • Donald DCruz
    Donald DCruz Aug 29, 2010
    Yes if your plug was hot there is fault at the powerr supply. The cost may range from about $80-100 with the dealer.
2003 Landrover Freelander SE V6 == Service Engine Soon (not Check Engine) light has been infrequently flickering on/off for the past 8 weeks. While light is on, engine hesitates slightly.Vehicle would not...
If it won't start have a compression test done and see if one bank doesn't have compression . The intake cam is known for breaking at the front lobe
Nov 09, 2011 | 2002 Land Rover Freelander
Tape door won't close i get error message reattach power. i've reset , used different power supply, still tape door won't close any goo ideas? chuck
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Sep 12, 2011 | Sony Handycam DCR-HC96 Mini DV Digital...
It'll turn on and run but it flickers the entire time. its happened before but quits after a while. this time though, it won't stop. any suggestions?
Best bet would be to unplug it completely and let it sit for about five minutes, plug it back in and turn it on, if it's still flickering there's more than likely something wrong with the backlight or the power supply. All Insignia TV's carry a 2 year manufactures warranty, so if it's less than two years old just take it to a Best Buy and have it serviced. It'll be gone for a few weeks, but either issue is an expensive fix.
Aug 27, 2011 | Insignia NS-LCD37 37 in. LCD TV
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Bad CV Joint?
Did you notice any leaks from the power steering? If you did not notice any leaks, the only place for the fluid to go is in the bellow boots(the accordion boots on the rack and pinion system). Go underneath and if no leaks are obvious, take a small screwdriver and poke a small hole in one of the boots. If fluid comes out, you're looking at replacing the rack and pinion. This would also explain the excessive play you're feeling in the steering.
Feb 25, 2010 | 1992 Oldsmobile Cutlass Supreme
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
187 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
