Question about Jura Capresso Impressa E9 Espresso Machine & Coffee Maker
Get "error 8" often and machine freezes up. after multiple turning on and off it does correct itself but is occurring more and more often.
  • Jura Capresso Master
  • 1,711 Answers
We have here the istructions for your problem<br /> <a rel='nofollow' href="http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8">http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8</a><br /> <br /> Thank you for using FIXya
Posted on Aug 30, 2010
Put mario cart in and go through until it says error occured eject and turn off etc but it will not turn off
This error occurs if you have a problem with the disc. This normally happens if the wii console cannot read or recognize the game disc and freezing usually occurs after the error. You need to restart the wii console if this happens. Also check the disc for any visible damage and try cleaning if dirt is present. If this happens on all or majority of your games, there could be a problem with your wii's disc drive, but if it only occurs on a specific game then the problem is with the disc itself. Good luck!
Jul 21, 2011 | Nintendo Wii Console
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
"error occured,call service person
Try unplugging it for 10 minutes. While unplugged, press and hold the start and stop but for 10 seconds. Double check for any paper jams. Just the smallest piece can jam it up. There should be a list of error codes for anything wrong. List paper jam would have an error code, change toner, change or clean ink, ect. Is this the only message you get? If that's so, try the steps I mentioned above so the machine resets itself. It the problem still occurs, let me know I will gladly help you to correct this problem.
Jan 27, 2011 | Kyocera Copystar CS-1820 Black and White...
My gamecube freezes in the middle of a game and says an error has occured, it tells me to check the gamecube manual but i don't have one! PLEASE HELP!
  • An Error has occurred:
    If you are getting the specific message, "An error has occurred. Turn the Power Off and check the Nintendo GameCube Instruction Booklet for further instructions." This means there may be an internal problem with the system.
    1. Check Individual Game Disc problems or Multiple Game Disc problems (depending upon how many games exhibit the problem) to see if the cause of the message is a dirty or damaged disc.
    2. If the disc appears fine or works properly in another system, this means there is an internal problem with the system. A repair will need to be set up. Please use our convenient repair options.
  • Aug 03, 2010 | Nintendo GameCube Console
    Freezes up
    Hello, Trravrrn.
    Naturally that can happen due to multiple, multiple reasons. Many are natural known ones like viruses, hardware failures, and software errors.
    What I'd say is go to the problems section and restate this question you asked again but instead state some of the recent changes you have made to the computer itself.
    Dec 15, 2009 | Acer AX1700-U3700A PC Desktop
    H2 error when printing from pdf to A3 in multipurpose tray
    H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
    Here is the info from the factory service manual:
    H2 The length of the paper set does not
    match that of the paper actually taken
    up and fed in.
    • Load paper of the correct size again
    according to the set paper size.
    • Turn OFF and ON the Power Switch.
    • For copier tray: Slide out and in the
    paper tray in which the size error has
    occurred.
    • For Manual Bypass Tray: Place paper
    in the Manual Bypass Tray.
    • For Multiple Bypass Tray: Unload
    paper from the Multiple Bypass Tray,
    then reload it back again.
    Nov 23, 2009 | Minolta Di152 Laser Printer
    Laser Error Error message 061-370 for Xerox Phaser 6125
    From the service manual:
    Troubleshooting Procedure Table
    Step Actions and Questions Yes No
    1 Check the Laser Unit for correct
    installation.
    Is the Laser Unit correctly installed?
    Go to step 3. Reinstall the
    Laser Unit. Go
    to step 2.
    2 Cycle the power.
    Does the error still occur?
    Go to step 3. Complete.
    3 Check the wiring harness connectors
    P/J40, P/J41, P/J411, and P/J412
    between the MCU Board and the Laser
    Unit.
    Are the connectors securely
    connected?
    Go to step 5 Reconnect the
    connectors. Go
    to step 4.
    4 Cycle the power.
    Go to step 5. Complete.
    5 Replace the Laser Unit (page 8-31).
    Replace the
    MCU Board
    (page 8-59).
    Complete.
    Jan 31, 2009 | Xerox Phaser 6125 Laser Printer
    Frozen white/stripy screen this time!!!!
    press the power/menu button until the player turns off. after than perform recovery mode and try to update the firmware of the player to the latest one which i believe is .18A. :D
    Aug 14, 2007 | SanDisk Sansa e250 MP3 Player
    Jura Capresso Impressa E9 Espresso Machine & Coffee Maker Logo
    475 people viewed this question
    Top Jura Capresso Coffee Makers & Espresso Machines Experts
    Colin Stickland
    Colin Stickland
    Steve
    Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
