Question about Kitchen Ranges
Whirlpool Oven RF368LXMS wont work. A contracter hit the power line and the power went down. After the power was restored the control panel wouldnt work at all...the burners work fine.HELP any one know what could be wrong?
  • Kitchen Ranges Master
  • 17,129 Answers
The control panel contains the timer/processor for the settings of the program and temperature measurements. A high surge could have had a damaging effect on the delicate electonics. so if there is a step down transformer , please check the primary for an open winding. If so you can change with the same type but if there is power on panel without any resulting display the mP IC would have failed. Might have to check cost of a new panel to decide.
Please look into the panel and comment.
Posted on Aug 29, 2010
Brand new double oven. Whirlpool W10795444B. Oven pops when heating up and cooling down. Seal problem?
That is due to natural expansion and contraction of the metal oven linings and is normal.
Apr 20, 2017 | Whirlpool Ovens
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Power Failure while oven was in self cleaning mode. When power was restored the control panel is completely dark, no error codes or PF indicator. The oven door is also locked after 24 hours, so the the...
Hello. You have an open rear oven thermostat causing the complete power failure of your unit. The part numbers you need are W10176670 for the upgraded blower and 9759243 for the thermostat. You will have to remove the oven from the wall in order to remove the back covers to access the thermostat and blower. The blower has been upgraded from 950cfm of airflow to 1200cfm. I have performed this service flash--you will definitely need a helper or 2 in order to pull the oven out and work on it. There is a service bulletin on your oven describing this exact situation. When you replace the thermostat and blower, re-mount the oven and then restore power, the oven will function and unlock. The link for the thermostat is here:
Thermal Overload Safety Thermostat
The link for the blower is here:
http://www.appliancepartspros.com/whirlpool-blower-w10176670-ap4369539.html
If you are hesitant about performing the repair yourself, definitely call for service. I hope this helps you!
Nov 06, 2015 | Whirlpool RBS305PRS Stainless Steel Oven
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
My house got hit by lightning, the control panel went blank burners work but not oven
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 30, 2010 | Whirlpool RF380LXPS Electric Kitchen Range
Oven just turned off
It sounds like your microprocessor in your control board is damaged. You can leave the power off for as long as a week to see if it will reset. If it comes up the same way, it's an electronic problem with the display driver. Frigidaires usually display an "F1" code. Any way, power down, wait at least 3-5 days, power up, clear, reset time and see how it goes. If it happens again, you may have to get a new oven control board/display.
Jul 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Complete functioning control panel but nothing works.
This is a problem with the control panel assembly, which we repair nationwide for $32.50 postpaid. Sometimes the bulbs short when they fail, and that damages the control board. This also can happen when bulbs are removed or installed without first unlugging the oven or turning off the breaker. For critical safety & disassembly info and other details of our service, see http://tinyurl.com/yzjozk
Jan 16, 2007 | Whirlpool MH1140XM Microwave Oven
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
