Question about Sony Cyber-Shot DSC-F828 Digital Camera
When I touch the cover where the CF memory card is located then an "access" warning appears on the viewfinder following with the text "REC folder is 101MSDCF".
Yep - same problem as mine. It is the CF Door switch that is at fault. Door on my F828 is a little loose now
Posted on Sep 02, 2010
Memory card size
i think those photos save in your camera built in memory. took the card out and turn on the camera . NOw press the play button and see the photos appeared in screen or not. If yes then you have to make the default storage location as your memory card.
Aug 07, 2012 | Nikon Coolpix 2000 Digital Camera
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
My mobile is nokia x3-02 and my memory card password is lost
follow this procedure 1. Insert the Micro SD card into your card reader on your computer. Right-click your Start button and then click Explore. Find the Micro SD card, it will be listed as a removable disk.
2. Click on the microSD card and files appear on the right. Locate the file MMCSTORE and then choose Copy.
3. Click directly on your desktop, then click Paste. This will move the MMCSTORE file on the desktop, so you have edit access.
4. Right-Click on the MMCSTORE then click Open With. Open the file with Notepad.
5. Read the text for the password. It will be in plain text.
6. Remove the SD card from the computer and insert it into the device, which it used as a warehouse. Turn on the camera. When he asks for a password, enter it.
Oct 31, 2011 | Nokia X3 Touch and Type Cell Phone
My sny cyber shot DSC-W120 camera doesnot allow me to take snaps at my memory card rather all the snaps stored at internal memory, which leads for maximum 5-10 snaps. How to avoid this, so that i can take...
Hi!
Please follow these steps in order for you to store snaps in your memory card by default:
  1. Press HOME
  2. select Manage Memory > select Memory tool
  3. Press Change REC. folder then select your memory stick or the folder which you want to save your pictures to.
Thanks!
Jun 13, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
How to copy photo from phone memory to memory card?
DEAR SIR,
YOU CAN DO That BY FOLLOWING THIS METHODS:
1.start your phone and access main MENU and then find out FILE MANAGER icon from menu,it may be located in application folder or settings folder.Their will be two sections one PHONE MEMORY and MEMORY CARD ,first locate your photo files (it may be in phone memory - images) and select your destination photo files,and select OPTIONS -ORGANISE -COPY TO FOLDER and select MEMORY CARD (you can copy it to any folder of the memory card)
2.by simply
MENU - FILEMANAGER - select - PHONE MEMORY- IMAGES- PHOTO FILE -OPTIONS - ORGANISE - COPY TO FOLDER- MEMORY CARD -ANY FOLDER-and press -COPY - icon
plese follow this order and make a smile
thank you
Dec 26, 2010 | Nokia X3 Cell Phone
How to transfer photos from CF to desktop
Hello
OK, firstly, you basically have 2 options.
Firstly you can put the CF card in a camera and transfer the data using the USB cable.
Or
You can buy yourself a CF card reader , as seen in the image below.
This is the easier and much more convenient way of performing this task. You wil be able to buy this reader at any computer or camera store for about $20.
please feel free to let me know if you need any further assistance.
Kind regards
Andrea
Nov 11, 2010 | Dell Dimension 5150 Intel Pentium 4 w/HT...
How can I change RAM in my panasonic toughbook 29
CF-WMBA5512
512MB Memory Card , supports your notebook , it is very easy , just open the back side cover where memory is residing , press the hook by your finger on the memory chip , it will easily open , and change or upgrade . By the way this model is absolute , very difficult to get the new memory .
Aug 28, 2009 | Panasonic Toughbook 29 Touch (P/N...
Some errors
Download the ATA PCMCIA/CF-Card update drivers* (file name MP8Pcm.exe) from ftp://ftp.necsam.com/pub/versa/mobilepro/. Click on the link to download. After the files are extracted, follow the installation instructions in Readme.txt. *This module requires 40KB of internal RAM memory. If the MobilePro has been Hard Reset or Main memory has been erased due to main/backup battery low, this module should be re-installed.
Sep 15, 2005 | NEC MobilePro 800
Some errors
Sep 15, 2005 | NEC MobilePro 770
Sony Cyber-Shot DSC-F828 Digital Camera Logo
124 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
