Question about Sharp ENERGY STAR AF-S60FX Thru-Wall/Window Air Conditioner
The air conditioner runs for a little while then shuts down and flashes the number 31. I cleaned the unit and the filters, but it still does it. What could this mean?
    President:
  • 3,074 Answers
This may help
1) Disconnect power
2) Hold down on/off while plugging cord back in, til you hear a beep
3)unplug again
4) plug in
5) start a/c
Hope this helped Tim if not then I would call the 1-800-237-4277
Posted on Aug 29, 2010
Enigma SLR61-GW. System runs for about 30 mins and then shuts down and a status light blinks 4 times.
Open the front end of the blower.
You will find tow filters that slide out.
Clean them with water and replays them.
Go to the outside one, take a hosepipe and run a strong stream of water thru the radiator until its clean.
This will solve your problem.
Good luck.
Oct 23, 2015 | Heating & Cooling
We have a hvac Nordyne model P3RA-048K Everything
Hello
Either the filter is clogged and needs to be repaced.Or check the coil inside the unit and see if it is getting iced up.You can try shutting the unit down for an hour or raising the temp.If this helps the motor speed then you know the coil was iced up.
It is also possible the motor may be going bad,doubtfull though since they will run for a while then shut off.
Check your filter
Check for ice
Possibly clean the inside coil.
Jul 31, 2011 | Intertherm P3RA-048K Air Conditioner
I HAVE A SCOTSMAN MODEL NUMBER QD0452A SERIAL NUMBER 991262644 I HAVE RESET IT BUT IT KEEPS SHUTTING DOWN AND FLASHING RED CONTIUNSLY
Normally that means needs to be cleaned. The air filter needs to be cleaned, and if you have a air compressor, blow it out and clean it as good as you can. Also of unit comes out easily, you can also hose it out, and let it dry completely with help of using air compressor to blow out excess water, then run on fan only to help dry, then once completely dry, then turn to cold.But bottom line here it is most likely dirty.I hope this helps you. Thanks Mike from fixya.
Jul 02, 2011 | Heating & Cooling
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
Carrier model #58rav070-08 flashing error code #31
I would check the back of the unit to see if any debris has accumulated then check for the filter and make sure it is clean. Look at the front of the a/c where the filter sits and see if the coil behind the filter is dirty. If so the unit needes to be cleaned. This can be done by purchasing a can of coil cleaner at the hardware store and follow the directions to clean the coil. What the system is saying is there is a blockage somewhere causing this code. Not being serviced in 4 years would be the possible cause because of the amount of debris in the air over that 4 year period. Good luck on the repair hope this helped you.
Dave
Dec 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Stops working and flashes 53
you need to check the re=turn air filter and kmake sure that its clean/. Basically it shuts down the ignitor due to high outlet air temperature. Stay Warm!!!
Dec 26, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Jun 09, 2008 | Frigidaire FAA065M7A Air Conditioner
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Sharp ENERGY STAR AF-S60FX Thru-Wall/Window Air Conditioner Logo
123 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
