Question about Dayton Heating & Cooling
How to remove cover from Drayton Lifestyle LP522 dual channel central heating programmer to allow retiling of wall?
5 Suggested Answers
  • 44 Answers
SOURCE: I've a problem with my
Hi you never mentioned which programmer the LP522 replaced, as the LP522 is a 5/2 day programmer.
you may of wired directly to the heating on terminal on the programmer?
It may of been that you had a basic programmer which was only designed for the system you have installed.If i know what existing programmer was used i may be able to help?
Kindly
Richie
Posted on Dec 15, 2008
  • 2463 Answers
SOURCE: My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Posted on Feb 01, 2010
Testimonial: "thanks"
micromatikal
  • 2777 Answers
SOURCE: I need a user manual
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
I have two here, one that is for a "Drayton Lifestyle LP522" which is this one:
http://micromatikal.dlinkddns.com:8000/cust/lp522.PDF
And one that is just a "climate control Lifestyle LP522", I would think it has to be one of these two, but please let me know if it isn't, here's the other one:
http://lp522guide.tripod.com/sitebuildercontent/sitebuilderfiles/lp522guide.pdf
Posted on Oct 14, 2010
  • 49 Answers
SOURCE: i have a honeywell ST700
If both thermostats only operate as a make break contact then yes they can be interchanged, providing the voltage is the same. If they are battery operated you wont have a problem as the relay contacts will be voltage free.
Posted on Feb 24, 2011
Drayton LP522 Heating & Hot Water Programmer
Mine is a different brand but looks similar if yours has a drop down panel which you open to set the times and to alter for winter summer in this panel you will see a very small hole Take a ballpoint and insert in the hole and press this is a reset button that the electrician told me about when mine went wrong it is not marked but it is a tiny button inset in the hole
Apr 12, 2014 | Heating & Cooling
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
I have Drayton Heating System in new home. I seem to be unable to put my central heating on without also having the water heater on. The boiler will come on if the water heating and central heating is on...
you will only be able to have the central heating on seperately if the system is fully pumped. Why would you not want the water to heat? it is more cost effective to use the residual heat to heat the water and keep the temperature up. Costs alot more to heat a cold house and a cold water tank
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
Hi, I am having problems with the timer that controls my boiler. It is a 'Lifestyle LP522'. The hot water is set to come on in the morning for 4 hours and again at 4pm for 3 hours. The heating is...
then there must be a problem with the programmer as the boiler thermostat will call for heat only if the programme is on try setting the water side to 24 hrs it won't cost any more to run , but will prove if programmer is working .
Mar 07, 2017 | Heating & Cooling
I need a user manual for Siebe Climate Control LTD "lifestyle Miodel LP522 control
Oct 14, 2010 | Heating & Cooling
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
I've a problem with my central heating, I've changed my central heating programmer to a drayton lp522. My heating is constantly on. The only way that I am able to turn it of is with the thermostat when I...
Kindly
Richie
Dec 03, 2008 | Water Heaters
Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Oct 26, 2008 | Water Heaters
Heating & Cooling Logo
181 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
