Question about Car Audio & Video
Burning smell and smoke coming from the unit - also the screen starts flickering and stops working altogether but music keeps playing just the screen goes off and has lines running thru it
    President:
  • 2,712 Answers
Get it replaced.
Posted on May 08, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Heater and aircon not working,loud rattling noise and smoke from vent,now not power to fan
It appears your fan itself burned out. When a field coil of an electrical fan burns out it usually makes a lot of smoke. The noise could be something that fell in there that stopped the fan from turning freely. I can imagine it heated up under the strain and burned out.
When you restarted it was burnt out so hence no noise and no fan.
The smell of the smoke should also be clue. Electrical field coils burning has an awful soury type of smell.
Aug 13, 2012 | Peugeot Partner Cars & Trucks
Screen is black and it smells like something is burning, but we cannot see any visable burnt wires or anything...we have removed the back of the tv, and looked at the circuit board...where exactly sho
Unless you know what you are doing you are playing with fire, Unplug the set and have someone qualified take a look at it. Smoke and a burning smell and you still have it powered up?
Apr 11, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Chevy Aveo strange smell and smoke coming through the vent with air conditioning on. Checked engine-OK. Turned up air conditioning full blast...after 30 seconds...little more smell and smoke it stopped...
If the blower motor is still working, that was not the problem-the strange smell might have been from some bacteria in the plenium, and the smoke may have just been the result of condensation from the evaporator in the plenium-keep an eye on it, but if the blower is working, I would not be overly concerned about it.
Jul 20, 2011 | 2005 Chevrolet Aveo
Smokes really bad at the beginning, but after you drive the car for 15 min or so it almost stops. What could that be?
Hi :) What is happening? you say Well when you shut the engine down the oil is hot and it runs by the valve stems because the stem guides are warren out and sits on the piston till you start the engine next time. It take a bit to burn it off then it burns clean till the next time you stop running the engine for any lenght of time.Take it in to the shop and have new valve guides put in it or unbrella seals put on under the valve spring this will stop the oil from leaking past the valve stems. I put a cup of transmission oil/Fluid/Dexron2/3 every time i change my oil to keep my valve seals soft and rubbery and it helps
Mar 03, 2011 | Nissan Maxima Cars & Trucks
Stopped working, burning smell, clicking noise while plugged in.
have a technician check it out. burning smell is always fire hazzard. A connection may have gone loose or connections are soaked.
May 12, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Xbox stopped
afraid to say your xbox is screwed call there support line to see if they have any ideas at 1-800-4myxbox
Dec 29, 2007 | Microsoft Xbox Console
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
