Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 Printer cartridges changed and now the paper wont align
Can anybody help? I've changed both my black and colour ink cartridges. The printer is not asking me to place paper in so that it can align the carteidges, only problem is the paper keeps pulling to the left and then getting stuck. Any ideas? many thanks in advance xxx
    Genius:
  • 3,587 Answers
Sure..one of the print cartridges seems to be out of sorts.
Posted on May 07, 2008
Just got a X5470 printer from a friend of the families. Said he was not sure what was wrong with it. I didn't have the cd so i installed it offline. It says that I have colored and black ink, have...
Make sure you are inserting the correct cartridges for your model. The Lexmark X5470 uses 32 or 34 black cartridge and the 33 or 35 color cartridge.
Try to follow the steps below to identify and fix the problem:
  1. Open the printer cover and remove the cartridges. Check the encoder strip (transparent strip usually found behind the cartridge carrier) and make sure it has not gotten unseated from its position.
  2. Close the cover. Unplug and re-plug the printer into the power source to reset it.
  3. When the printer turns on, check for any errors on the printer display screen. If "alignment problem" error appears, please contact Lexmark Technical Support Center for additional assistance.
  4. If no error appears, reinsert one cartridge first. Close the cover and check for errors.
  5. Reinsert the other cartridge.
  6. Replace whichever cartridge is causing the error to appear. It may be faulty. You may also try to insert a different known working cartridge to determine if the cartridge you're currently using is defective.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Ink cartridge prob
Try to remove the color cartridge from the printer and manually clean the cartridge nozzles with a damp paper towel. Here's a link to the Lexmark website to guide you on how to manually clean the nozzles http://bit.ly/9wzuAL. If this fails, maybe the cartridge has defective contacts. If this is the case, I suggest you contact Lexmark Technical Support for further assistance. Thanks.
May 16, 2010 | Lexmark X5470 All-In-One InkJet Printer
Alignment problem
Disconnect from computer - remove cartridges - wipe the bottom of them - not the side - reinsert - reconnect - try again - should ask to realign cartridges... cheers
Jul 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
Put in a new black ink cartridge #32 in my lexmark X5470
Try arrowing down on your screen to maintenance press the tick to select maintenance and then scroll down to align catridges. see if this works
Jun 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
Let the ink settle in the cartridge for awhile. Make sure no ink is on the outside of the cartridge which adversely effects the signal to the printer.
Apr 14, 2009 | Dell Dimension 4500 + Lexmark Z35 Printer...
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
I refilled a 33 colour cartridge still says low
I would like to inform you that Lexmark printers does not support refilled cartridges. Please note that #33 cartridge is know as a rushmore cartridge and in this cartridge it has memory chip on it to identifiy the ink estimation. hence it is not possible to change the low ink indication.
Please note: using refilled cartridge may void ur printer warranty.
Apr 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Compatable black ink cartridge
Is the print out normal? If the print out is normal you just need to reset the software to know that you have a new cartridge.
If you open the printer cover, remove and then reinsert the cartridge you should have a message on your display asking you to align the cartridge. When you do this it will reset your ink levels.
If you are using a brand new Lexmark cartridge this should work find. If you are using a refilled cartridge then you will still see the cartridge as they are not supported on Lexmark products.
Thanks
Catherine
Sep 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
The messages Appears when the catridges are not inserted correctly........ Install the Colour Catridge on the Right Side and the Black should go in the Left Side...... Thanku
Jun 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
179 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
