Question about Harman Kardon Harman Multimedia TC-30 LCD Remote Control
No longer possible to add devices and/or the update remote with changes in activities. When trying to add devices I simply get a white screen with not options; when trying to updating the remote after adjusting an activity the software gets stuck and only a Windows "kill programme" can end the software. I am running the latest available software from HarmanKardon (5.1.4) (Logitech) and fully updated Windows XP incl Java. Dissabling the Firewall Anti Virus does not help It pretty much seems like the TC 30 is no longer supported (e.g. no Vista or Windows 7 version of software.
4 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: I need the correct universal remote code for
The Code that you will need is the code that comes with the "universal remote" not the receiver's code. Every remote manufacturer will have a different code to control the same piece of product. Look for the manufacturer of the remote's website and search thru support. If you have the exact model # of the remote you are trying to use, post a comment and I can try and find it as well. Hope this helps
Posted on Nov 07, 2009
  • 19 Answers
SOURCE: I was updating my Harman Kardon AVR 2600 and it froze now I don't get any video out, what should I do?
Don,t update it anymore,
Posted on Dec 03, 2012
HOW DO I ACTIVATE MY YOUTUBE ACCOUNT ON MY SONY BDP S3200
I would say the easiest way is to buy an inexpensive universal remote. Keep the receipt in case it does not work. If the remote does not work with the system then simply return it, and try another.
Although this might seem like a headache it can be better then sitting up all night trying codes that will never work for the DVD Player you have. I have been through this frustration before.
Some DVD players are hard to match with remote. Have you contacted the manufacture to see if they know a remote model that will be compatible with the equipment you are using?
Dec 08, 2014 | Sony BDP-S300 Blu-Ray Disc Player
Remote wnt black @ reads go to website to update settings but that doesn,t help
Simple and surprising solution.
Change the name of an Activity or Device and update again.
This solves the problem.
May 12, 2010 | Logitech Harmony One Advanced Universal...
Everything works except no picture of tv
The Television may be out of synchronization with your remote or may be configured incorrectly.
1. In front of your Television, press the Help button on your Harmony Remote.
2. Answer No when asked "Did that fix the problem?"
3. The Harmony will then ask, one by one, if all of your required devices powered on when the Activity was started. Answer Yes or No until all required devices are powered on.
4. Answer No if the remote asks if the TV is set to the correct input needed for the Activity. In this example Input 4 is used, though this may vary from your setup. If the TV switches to another input but no picture is seen, continue answering No until an image appears.
5. If you now have a picture on your TV screen, answer Yes when asked if the problem is now fixed. Your television was simply out of synchronization with your Harmony One and should now work correctly. Please try switching between your other Activities to see if they switch correctly. If this has not fixed the problem, proceed to the next section Confirming your Activity Settings.
To confirm your Activity Settings, please follow the steps below:
1. Launch the Logitech Harmony Remote software and login to your account.
2. Click on the Activities tab on your home page
3. Click on the Settings button for the Activity you wish to troubleshoot.
4. Select Review the settings for this Activity and click on the Next button.
5. Confirm the input chosen for your television is correct. Select No, I want to run the setup wizard again to change these settings and click on the Next button.
6. Click on the Next button through the Activity setup screens until you arrive at the screen asking the question "What input or channel does your ... TV need to be on? From the list, select the input that the TV uses for this Activity. Once finished, click on the Next button.
**NOTE: It is recommended to perform these steps for all Activities that use the television.
8. Click on the Done button on the Set Up Activities: Summary page.
9. Click on the Done button on the "Select the Activity settings you would like to modify" screen.
10. When you have finished, click Done to save your changes.
11. Click on the Update Remote button to update your remote.
Jan 17, 2010 | Logitech Harmony 966208 Remote Control
Volume buttons have to be pressed hard to work
Try mapping the Volume buttons to the LCD screen in each Activity you use them in. To do this, see below.
2. From the Harmony homepage, click on the Customize Buttons button for the Activity you wish to customize.
Additional Buttons:
To modify commands on the LCD screen, click on the Additional Buttons tab at the top of the page.
a. In the Button column, select the button you wish to customize, from 1 to 4 for each page. The illustration of the remote below shows where each button is placed on the display.
b. In the text box in the Button column Type in the name of the button.
c. In the Device column, select the device you wish to send the command to.
e. In the Command column, select the command you want from the dropdown list
f. You can delete a command by clicking the trash can icon beside it
g. You can move commands to different button positions by using the arrows
h. Click on the Add new Page button to add another page
i. Click on the Learn Command button if the command you need is not in the drop-down box. You will be able to capture the button from your original remote.
j. Click on the Add Sequence button to create a custom sequence of 5 commands for a single button.
k. After making any changes, ensure that you click on the Done button to save the button customizations. The last step is to update your remote.
l. Connect the Harmony to your computer’s USB cable and click on the Update Remote button on the Harmony homepage
Test the commands on the LCD. if they do work id advise you to contact logitech.
Jan 14, 2010 | Logitech Harmony 880 LCD Remote Control
Changes to fios and have motorola 7100 program my harmony 880?
If you have changed your hardware setup, you must reprogram your Harmony 880 using the Logitech software. You should be able to simply step through the 'interview-like' process and enter the new make and model number of the new hardware. It is usually recommended to add the new device first and then associate the new device with your existing Activities. Once your Activities have been mapped to use the new device, you can delete the old one. Once everything has been completed in the software, update your remote through the USB connection. Hope this helped!
Jan 12, 2010 | Logitech Harmony 880 Universal Remote...
My Harmony 890 won't exit USB mode. I made some changes in the software, updated the remote, and when I unplug the USB cable, the remote continues to think it is still connected to USB, until I remove the...
  1. Ensure your are using the latest version of the Harmony Client Software. (Pairing is done in the software and the newest version is needed) 7.7.0 if you dont have it, see below
  2. Ensure that the `Control Devices` are assigned correctly to the Remote & Extender
  3. Update the Firmware in the extender and remote
  4. Update the configuration
  5. Test the remote
Did this fix the problem? If no, see below
Do the `Status` and `RF` lights on the RF Wireless Extender blink when you start an activity or press buttons in a device assigned to the RF Wireless Extender?
if no, Please try the following:
  1. Plug the RF Wireless Extender in AC power only
  2. Reset the RF Wireless Extender by holding down the `Connect` button on the RF Wireless Extender until the `Status` and `RF` lights start blinking back and forth. (This process takes longer than 60 seconds, and the `Connect` button will need to be held down for the entire time)
  3. Once the `Status` and `RF` lights start blinking, let go of `Connect` and unplug the RF Extender from AC power
  4. Upgrade the firmware on the Extender
  5. Update the configuration
  6. Test the remote
if no, contact logitech.
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
NEW SOFTWARE:
1. Go to www.logitech.com.
2. Hold your mouse over the Support Tab.
3. Scroll down to Product Support.
4. Choose Harmony Remotes.
5. Choose your brand of Harmony Remotes.
6. Click on Downloads on the right side of the screen.
7. Choose your Operation System (OS)
8. Click on the Download Software button on the bottom of the page.
9. Choose Run.
10. When the software is completed downloading and installing, please open the software.
11. Once the software is open, click on Update Remote.
12. Follow the on screen steps to complete the update.
Jan 05, 2010 | Logitech Harmony 880 LCD Remote Control
How do i program my remote?? it did not come with any software?
follow steps:
Download software:
http://www.logitech.com/index.cfm/440/379&hub=1&cl=us,en?WT.z_sp=Image
Create an account
How to find model numbers for devices:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11210
Add devices:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11462
Add Activities:
1. Login to your Harmony Remote Account.
2. Click on the Activities Tab.
3. Click on Add Activity.
4. Choose the Activity from the Activities in the list you would like to create.
5. Choose No-I would like to manually add Activities.
6. Continue through the setup choosing settings to answer the questions at the top of the page.
7. Once you have finished adding your Activity, please update your Harmony Remote.
Dec 25, 2009 | Logitech HARMONY 659 Remote Control
How do I make this work as I have everything hooked up. I am using a Harmony advanced universal remote 1100
Firt press the sensor button and then press the device button . Here go on doing this untill it works, i say that it will work 100%. Plz give me more ratings.
Nov 15, 2009 | Logitech Harmony RF Extender IDE / EIDE,...
Volume control
Try this:
2. Click on the Settings button next the Watch TV Activity.
3. Choose Review the settings for this Activity.
4. When the software asks what device are you using to control volume, please choose the TV.
5. Continue through the setup until you are brought back to the Home Screen.
6. Click on the Update remote button and follow the on screen steps.
7. Once the update is completed, please test the Watch TV Activity.
Jan 09, 2009 | Logitech Harmony 550 Remote Control
Harman Kardon Harman Multimedia TC-30 LCD Remote Control Logo
104 people viewed this question
Top Harman Kardon Televison & Video Experts
Electro Med Services...
hims Patel
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
