System Administrator Thanks for your suggestion. I tried what you sugested without success. Before I did the restoration I had two log-on profiles plus one for a guest. I now have only one and it is called Administrator on the log in window. It does not have a password space and once I log in the computer doesnt allow my administrative privilges. As for the control panel, I am unable to go into its properties because it isnt visible. When I attempt to fo into program access I geta a banner stating: (This operation has been cancelled due to ristrictions in effect on this computer. Please contact your system administrator.)
    President:
  • 778 Answers
You're Welcome.
I wasn't suggesting you access Control Panel properties, but your start folders properties to add control panel back to it.
As for the user/Administrator account issue, you could try a system restore (I rarely if ever suggest this) to a date prior to the issue and that may get you back into control.
Also if no one else has had physical access to this computer? You may want to boot into Safe Mode (tapping F8 key on boot to key to the Windows boot option screen) and run a full virus scan as this issue doesn't seem likely unless it's viral in nature. Unless someone else has been messing around with it.
Posted on May 07, 2008
Need to restore laptop to earlier but it wont open restrore
Follow these steps hopefully it will help you
Log on to Windows as an administrator.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
On the Welcome to System Restore page, click to select theRestore my computer to an earlier time option, and then click Next.
On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete page.
If you successfully restored your computer to a previous state, and the computer performs as expected, you are finished.
After that simply get the Reginout because RegInOut is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors for the better performance of your laptop
Thanks
Jun 26, 2013 | Computers & Internet
How to get computer off a tempory profile
which operating system ?
Every time that you log on to a Windows Vista-based computer that is connected to a domain, a temporary user profile is created.
When you log off the computer, the user profile is deleted.
This behavior usually occurs because the account that you use to log on to the computer is a member of one or more of the following groups:
•Guests
•Domain Guests
If this is a school/work computer then this is most likely the way the NetAdmin has set it up.
If this is your home computer then a temporary user profile is issued each time an error condition prevents the user's profile from loading.
You may encounter profile issues if you log on with a user in the Guests group.
You need to remove the user in question from the local Guests or "Domain guests" group and that should do it.
1. Click Start
2. Right click Computer and Select Manage
3. Select Local Users and Groups > Groups
4. Double click Guests
5. Check if the user that is having the issue is a member of the Guests group
6. If so, remove the user from the Guests group
7. Log off the workstation and log back on
8. Verify the profile is now local
or
Try following these steps and check if it helps:
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly.
Therefore, make sure that you follow these steps carefully.
For added protection, back up the registry before you modify it.
Then, you can restore the registry if a problem occurs.
a. Log on to the system by using an administrative user account other than the user account that is experiencing the problem.
b. Back up all data in the current users profile folder if the profile folder still exists, and then delete the profile folder. By default, the profile resides in the following location:
%SystemDrive%\Users\UserName
c. ClickStart, typeregedit in the Start Search box, and then press ENTER.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
d. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
e. Under the ProfileList subkey, delete the subkey that is named SID.bak.
Note SID is a placeholder for the security identifier (SID) of the user account that is experiencing the problem.
The SID.bak subkey should contain a ProfileImagePath registry entry that points to the original profile folder of the user account that is experiencing the problem.
f. Exit Registry Editor.
g. Log off the system.
h. Log on to the system again.
After you log on to the system, the profile folder is re-created
hope this helps
or
1. Use SFC / SCANNOW command to help you detect and fix any corrupted or missing system files.
1) Go to Start menu, expand "All Programs" - "Accessories" - "System Tools", right-click "Command Prompt" in the pop-up menu, select "Run as administrator", then input "SFC / SCANNOW" without quotation marks and press Enter.
2) When the "SFC / SCANNOW" command is running, this command will scan every corner of your system, and repair the missing or corrupted files.
2. Shift to another administrator user, if you don't have one, please create a new administrator account and log in.
3. Navigate to C:\Documents and Settings folder, backup the data of your original corrupted profile, then delete the corrupted profile and all the temp profiles.
4. Open Registry Editor (type "Regedit" without quotation mark in the start menu blank and open it), search for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\ProfileList, under the profileList subkey, delete the key named SID.bak.
5. Restart your computer; you will be able to log in the normal profile again.
hope this helps
Sep 23, 2012 | HP Pavilion G4 G6 G4-1000 Series...
Have xp professional and on my start up page all my links are gone? cant even do system restore.how do you restore it or fix this problem, really need some help!!! also get c:\program...
How to use System Restore to restore Windows XP to a previous state loadTOCNode(2, 'moreinformation'); Note To perform System Restore, you must be logged on to Windows as an administrator. If this is your personal computer, you are likely already logged on with an administrator account. If this is a computer that is part of a network at work, you might have to ask the system administrator for help. To verify that you are logged on to Windows with a user account that is a computer administrator, visit the following Microsoft Web site: http://support.microsoft.com/gp/admin (http://support.microsoft.com/gp/admin) To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
If the restore process completed successfully but the computer is still not performing as you want, go to the "How to undo a system restoration after you perform a System Restore" section. If you received an error message and the restore process did not finish, or if you cannot run System Restore, go to the "Next Steps" section.
Jun 09, 2010 | Microsoft Windows XP Professional SP2
I no longer can run sotiaire of any of the games on Windows vista. This is not a business edition so clicking on the enable software will not work. I think I corrupted the file somehow. How can I retrieve...
Tony;
You could restore they system when it was working fine, by using the 'System Restore' Tool that Microsoft provides in the OS.
  4. On the Select a Restore Point page, click the most recent system restore point (or the date you know when solitaire was working fine) in the On this list, click a restore point list, and then click Next.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer.
  7. Click OK.
I hope this helped! If you need further assistance on how this process is done I will be more then happy to walk you through. Just let me know.
keiffertech@techie.com
Please don't forget to vote!
Sep 07, 2009 | Computers & Internet
When i turn on my pc, it showing one message every time"script file windows/system32/virus cleaner vbe. is missing.
  4. On the Select a Restore Point page, click the most recent system restore point in theOn this list, click a restore point list, and then click Next.
  6. Log on to the computer as Administrator. The System Restore Restoration Completepage is displayed.
  7. Click OK.
Thanks, PREM
Mar 31, 2009 | Microsoft Windows XP Professional
Cannot hear any sound
You can use Restore Point for this matter:
  • Note: To perform System Restore, you must be logged on to Windows as an administrator. If this is your personal computer, you are likely already logged on with an administrator account.
  • Log on to Windows as Administrator.
  • Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  • On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  • On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
Note: A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  • On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  • Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
    Click OK.
*If those steps doesn't work, reinstall the drivers.
Jan 01, 2009 | Computers & Internet
Booting problem
If the computer was working properly few hours/days back... then you can try it by restoring the windows to an earlier time by booting it in the safe mode.
How to go in the safe mode < click
How to restore the system>
  7. Click OK.
If the restore process completed successfully but the computer is still not performing as you want then its recommended to repair the windows.
Dec 04, 2008 | Dell OptiPlex GX260 PC Desktop
I try to log on but it wont show my desk top
I think you pc is virus infected...
try to restore if ..............
  7. Click OK.
rate me ..
regards,
Nov 22, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Xp logs on then logs off immediately on acer 5100
I'd suggest booting into Safe Mode (press F8 after the POST information is finished on bootup) and then you should see an option for Administrator. If you can sign in successfully there, go to Control Panel and create a new account under User Accounts. Boot normally after that and see if you can sign in the new account.
Two questions: 1) is this XP or Vista? and 2) did you recently make any significant changes to the software (namely try to change the Certificate of Authenticity)? If what I suggested works, I'd say boot into Safe Mode again and then run System Restore for Windows. Set the system back to about a week ago and try logging in normally.
Ben
Aug 22, 2008 | Acer Aspire 5100-3357 Notebook
Laptop doesn't normally start
This sounds like an operating system glitch. Enter safe mode at start up by pressing F8. Once in safe mode, log on as administrator and do a system restore to a point that you recall it allowing you to log onto your profile. This should cure it, if not, let me know and we'll try something else.
Jul 05, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
David Payne
David Payne
