Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can not fill up my 8 GB USB drive
Hello, I have an 8 GB data traveler USB drive. I plugged it into a USB port on my dell laptop which has Xp SP2 installed. It finds it fine, but I can not move two large files (Outlook PST files) over to the drive. The two files are a total of 5 GB, so I should have plenty of room. I get an error message though, drive does not have enough space. Is this an XP issue? I tried to reformat the drive. I tried to zip the files, which made the total 4 GB. Not sure what else to do?
    Problem Solver:
  • 15 Answers
Check your flash drive if you dont have any hidden files like porn.. wahahahhah.. just joking dude.. anyway..
go to control panel.. then appearance and themes.. folder options.. and then go to VIEW TAB.. under VIEW TAB..
click the SHOW HIDDEN FILES AND FOLDERS.. click APPLY or OK.. then check your flash drive...
Posted on May 09, 2008
Not working USB data travelter 4 GB message error is USB device not recognized plz solved this problem and send me best clarification.
Hello and Welcome to FixYa!
The error you quoted can be due to multiple reasons. Following are some main Possibilities, that you should keep in mind.
Make sure, the USB port, you are inserting data traveler in, is in working condition. And you are connecting the device properly.
This could happen due to Software conflict, for this you need to remove all the devices connected to USB ports (other than keyboard, and Mouse) and need to restart the system.. Moreover, you can check for the exact error, in the device manager list...
Try checking the data traveler, on some USB port, on which you are sure, that its working properly.
Check for the possibilities, quoted above and do let me know....
Concerned.
Jun 25, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have an Iomega GDHDU 2 external HD - 1TB. Just got it today, and when I plug it in it crashes XP (XP - SP2, 1.66GHz, 0.99 GB RAM, Del Inspiron Laptop 1420). I don't get the big blue screen, I get a...
Dell has stated in Dell knowledge base document FA1021802, that a USB device (such as a external hard drives, scanner, printer, etc) may not be detected or function correctly when connected to the USB port of a Dell Latitude or Inspiron PC (it may occur on other models as well).
Various communication errors may occur, including device initialization and device not found errors.
Some Dell computers do not provide enough voltage from the USB ports to power some USB devices.
Dell recommends purchasing a powered USB hub to provide the USB devices with enough power to operate correctly.
I think this explains it. Thank you and good luck!
Nov 01, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
When i plug in my kingston usb 8 gb the system message showen that the windows not recognize your device. i am using windows xp sp2 in my laptop plz solve my problem .... thanks
i recommend you try the usb flash drive in a different pc if it does not work you flash drive is corrupted if it works you might need to have your pc usbs checked out
Sep 26, 2010 | Computers & Internet
How can I retreive my files from a kingston 4GB DataTraveler
plug the 4kg data traveller it into a USB port open windows explorer open the data traveller select the files copy and paste into my documents on your computer
hope this helps
Aug 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
Apr 13, 2009 | Dell Inspiron 600M Notebook
Data traveler not recognize my computer
If you are using a USB Hub, try removing it and plug the drive directly into the USB port on the computer. I have a Dell laptop running Win 2k and sometimes have the same problem.
pxl8tr
Apr 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
163 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
