Question about Kenmore Dryers
Replaced Kenmore dryer heating element. Element worked initial after being installed one time. Turned dryer off and moved dryer back. Turned the dryer on a second time and it now wont work. Drum will turn but no heat.
    President:
  • 3,074 Answers
I would pull dryer and re-investigate the element to make sure no connection came off and to verify the coil did not burn in half. Hope this helps Tim
Posted on Aug 29, 2010
Kenmore 11086180100 heating element stays on even when dryer is off
The control relay is bad. Internal contacts are most likely welded together. Replace the relay.
Oct 22, 2016 | Kenmore Dryers
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Kenmore dryer, heat element ALWAYS on
Good day,
Sounds as if the element inside the canister has shorted to the canister body. You will have to remove the element to check it. I'll include a tutorial on how.
If that doesn't resolve the issue, please reply back.. Whirlpool makes Kenmore dryers.
Jack
http://www.applianceaid.com/wp_element.html
P.S. Look close. It doesn't take much....
Feb 01, 2010 | Dryers
The dryer continues to heat after it is turned
Was this the reason you installed the element and thermostat? Or did it start doing that after you installed the new ones? Maybe you have the spiral element portion touching the metal encasing aroung it. The element has Line 2 to it at all times so the ground will provide a circuit even when all else shuts off. Check for any other ground issues.
Nov 02, 2009 | Kenmore 800 6983 Electric Dryer
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
Dryer will not heat
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Feb 19, 2009 | Kenmore 65924 Electric Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Heating element
The model number you provided suggests that the lint screen is on top of the dryer, right? If so, the heating element can be accessed from behind the dryer by removing the rear panel. Of course, you should know this already since you stated you've already replaced the thermostat and fuse. The heating element is located on the right-hand side as you are looking at the dryer from the rear. There are TWO components on the heater housing. One is the high limit thermostat, one is a thermal cut-out. Are these the components you mentioned replacing? BOTH should read a short (0 ohms) when measuring resistance with the dryer turned off. If you haven't replaced both of them, double check to see if they are both good. The high limit thermostat will be located closest to the ceramic heater connection. The thermal cut-out will be mounted to the heater box. Perform a resistance check of the heating element as well. Measure across the leads of the heating element at the ceramic terminal connection. It should read between 8 - 13 ohms if good. If your readings prove that the heater is bad, it can be removed by using a 5/16" hex drive. The heating element should slide out the bottom of the heater box housing. Sometimes removing the heater box, and then removing the heating element is easier.
Your dryer is also equipped with an electronic cycle control board under the control panel that goes bad from time to time. This also may affect the dryer heating circuits. Inspect the small circuit board for any obvious signs of burned components.
I hope this information is helpful to you. If I'm wrong about your dryer configuration, please post back with comments, so I can give you proper instructions.
CAUTION: Make sure you UNPLUG the dryer prior to making any resistance checks. Dangerous voltages are still present with the dryer turned off.
PS I hope I'm not insulting your intelligence, here. As a rule, I tell everyone this information because some are not as savvy as others.
Feb 23, 2008 | Kenmore 63942 Dryer
Dryers Logo
53 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
